Old 08-19-2010, 10:42 AM
Cobra Make, Engine: factory five mkIII roadster 445 fe quick fuel 750 q series,irs
Question fe 4.25 crank and h beam rod question
i have a steel 4.25 fe crank with the eagle h beam chevy rods , the crank was not right and had to be cut. i wanted to know what is acceptable for rod clearance?
Old 08-19-2010, 11:18 AM
Rod bearing clearance or rod side/side clearance?
Old 08-19-2010, 12:05 PM
sorry, i wanted to know what is acceptable side clearance?.
Old 08-19-2010, 01:04 PM
I like to see about .016-.020, but I think the spec is .010-.020. However, if I were building one and it had .010, I'd have them milled a little. It's one of those things where too much is better than not enough.
How much you got?
Old 08-19-2010, 01:30 PM
Default What is the end play on the crank??
wrench87 What is the end play on the crank? Rod clearance I like to run about .020-.025" This number is with pistons in the holes, rods set to to torque spec or pull of rod bolts. This is with a crank at .006" end play. Rick L
Old 08-19-2010, 04:30 PM
Unhappy
i dont know all the particulars but he told me it had .027 side clearance this is with all new parts, my crank journals were offset the crank had to be cut he said it was like they cut the crank then hardened it and the journals were distorted. i am very unhappy with this whole fe experience, you should see all the problems i had with my stage 1 heads, diamond pistons, rpm intake all poor quality. i should of just built a 427 windsor with a dart block.
Old 08-19-2010, 05:09 PM
When your starting from scratch with a bunch of parts your trying to assemble, new or used, "stuff happens". You could be running into similiar problems with a W block combo just as well.
Old 08-19-2010, 06:11 PM
Side clearance of .027 is high - but won't really cause any problems. I have every single one of the RPM steel cranks I use cut/fixed - I do not even bother to try them out of the box. Almost sounds like your crank grinder got a little happy with the cheeks.
I use primarily Scat components in all of my kits and assemblies - they seem to be a good deal better in terms of dimensional control compared to the other importers. There is a reason that I use all the particular parts that I do....
Survival Motorsports
"I can do that....."
2008 - 429 cid FE HR - 675HP
2007 - 429 cid FE MR - 659HP
2006 - 434 cid FE MR - 678HP
2005 - 505 cid FE MR - 752HP
Old 08-19-2010, 07:46 PM
Doesn't excessive rod clearance result in lower oil pressure or at least more oil slinging off of the crank?
Old 08-20-2010, 12:32 AM
Bearing clearances and oil pressure/volume are what dictate the amount of oil thrown from the crank. Side clearance has nothing to do with it.
Old 08-20-2010, 06:01 AM
I'd like to hear other opinions on this.
Old 08-20-2010, 06:46 AM
DAVID GAGNARD's Avatar
me too..........
DAVID GAGNARD
Old 08-20-2010, 06:47 AM
Many engines have been built with a 1.771 Honda-size rod that is .675 wide on a 1.900 wide journal. Combined total side clearance is .550". Bearing clearance determined pressure and throw-off.
Old 08-20-2010, 07:33 AM
Jerry Clayton's Avatar
Bearing clearance determines oil flow UNLESS side clearance is inadequte
Lots of newer very high level engines use huge side clearance however they control rod placement by centering at the wrist pin---similar to a 2 cycle with top guided rods
Old 08-20-2010, 08:44 AM
In agreement with wht you stated, but to elaborate, side clearance would have to be very tight to be inadequate when you figure you have a total area of clearance of just over .004"sq. around a 2.200 journal with .0025 clearance and a .5" wide bearing. No more oil is going to pass through that bearing and come off that crank than that .0043" sq. of area will allow. Using the piston pin boss to locate and guide the rod instead of the crank journals, as mentioned before, allows narrower rods and bearings, less friction, less heat, less recip. mass, etc.
Old 08-20-2010, 08:52 AM
and they also now make bearings in the honda diameter and us type width
