Old 12-23-2010, 09:16 AM
RestoCreations's Avatar
Cobra Make, Engine: Kirkham 289 FIA, 363 Stroker
Correction, i dont have the 511 stroker kit, i have the 527 stroker kit. I hope that's a good thing. I keep getting surprises with the engine kit.
Old 12-23-2010, 10:07 AM
RodKnock's Avatar
Well, it's good then that you have a Shelby block and not a Pond block. BTW, was your Shelby block ordered with the "big bore" option?
Old 12-24-2010, 07:48 AM
Cobra Make, Engine: era 427cobra stroked 427fe
I have a canton pan and canton windage tray for sale for $200.00 . You can check it out in the for section on this site, its listed under loadco. its been powder coated silver and includes the pick up.
Old 12-24-2010, 09:21 AM
Rodknock- Yes, it is the big bore block.
Is there some reason that i do not want to use this rotating assembly? I was supposed to receive the 4.250 crank. I dont know what is going on with this company, but they are having major issues in the ordering department.
Old 12-24-2010, 07:48 PM
The 4.375 stroke will run just fine. But its gonna be pretty torquey in a Cobra - I hope you're ready for some tire spinning...
Survival Motorsports
"I can do that....."
2008 - 429 cid FE HR - 675HP
2007 - 429 cid FE MR - 659HP
2006 - 434 cid FE MR - 678HP
2005 - 505 cid FE MR - 752HP
Old 12-28-2010, 09:00 PM
Well if I was building a nice engine like 527 stroker Fe I would use the Aviad or Armondo and we use both. They are pretty much the same oil pan. If you use main studs in the rear cap and do not cut them down they will hit any of the oil pan back there unless it is a rear sump like for a truck. We use bolt in the rear cap sometimes to fix this as well. There is no need to have to do special work to the oil pan. We aloso handle the Canton and Moroso but they are a front sump t-style pan and work but are not what came on the car originaly. The Aviad comes with a windage trey included as well as pick-up tube. I think that it controls the oil better and holds about 2 quarts more than the other pans as well which I like. It is your high dollar engine and I would not cut corner on an oil pan set up.
Good luck, Keith Craft
Keith C
