February 2026
Old 06-14-2011, 10:00 AM
Grubby's Avatar
Cobra Make, Engine: ERA 838
Default FE hydraulic lifter adjustment -correct procedure?
My FE has some lifter tick on one bank and I want to adjust the valve train. It has a mild hydrualic cam with adjustable rockers. Just over 2000 miles.
I found two procedures;
1. Bleed the lifters and then set clearance between valve and rocker tip at .100" - .200". Obviously, each tappet must be on the base circle for adjustment.
2. Determine 0 lash by rotating the push rod until slight resistance is felt and then go 1/4 - 3/4 turns more. Each tappet must be on the base circe. This is the method I am familar with.
What method is used by the top FE builders like Keith Craft, Barry, Brent Lykins and others?
Thanks.
Old 06-14-2011, 10:47 AM
Set the intake valve when the exhaust valve is starting to open. Set the exhaust valve when the intake valve is starting to close. That ensures that the lifter is on the base of the lobe.
When you get there, loosen the adjuster up. I don't look for how freely the pushrod spins....there are too many variables there. I "feel" for how much axial play (lash) there is in the pushrod. When I get to zero lash, then depending on what rockers/lifters I have (not including short travel lifters), I go anywhere from 1/2 to 3/4 turn past that.
Just take your time and sneak up on it. The biggest part is making sure that the lifters is on the base of the lobe and that you have a feel for when you get to zero lash.
Old 06-14-2011, 12:23 PM
RestoCreations's Avatar
Cobra Make, Engine: Kirkham 289 FIA, 363 Stroker
I agree with Brent. move the pushrod back and forth in your fingers(twist) and move the pushrod up and down at the same time to determine your zero lash mark. It is difficult to find sometimes with the FE shaft rockers.
Old 06-14-2011, 12:48 PM
I follow the same procedure, except that I generally go about a full turn on customer engines. This is because the FE adjuster is directly on the pushrod, compared to the fulcrum and ratio affecting other engines. One full turn on an FE is +/- .040 in preload - a pretty good place to be with most lifters.
Survival Motorsports
"I can do that....."
2008 - 429 cid FE HR - 675HP
2007 - 429 cid FE MR - 659HP
2006 - 434 cid FE MR - 678HP
2005 - 505 cid FE MR - 752HP
Old 06-14-2011, 02:47 PM
PaulProe's Avatar
Cobra Make, Engine: Hurricane - FE
Default Be careful - Twist
be careful if you use the twisting the pushrod to determine zero clearance. My Crane Hydraulic rollers have very weak springs in them and it is extremely difficult to determine the zero clearance point.
I found it worked better to try and move the pushrod up and down, while holding it between your thumb and index finger. Found I could determine the zero lash point much more accurately.
The "rotate to determine" method works great if the spring in the lifter body is relatively stiff but in my case, it was very easy to make an error
Paul
www.65shlb.com
www.prdcrrct.com
Old 06-14-2011, 06:53 PM
Grubby's Avatar
Thanks guys. I just finished the adjustment and everything sounds as expected.
