February 2026
Old 09-09-2011, 06:56 PM
Cobra Make, Engine: ERA 427 SC with 428 PI
Default Regular volume or HV for FE 428
I have a 428 with hydrolic lifters and I would like to know which oil pump most people use for street driving, reg. volume or HV.
"Is it original ?" -- " Yes! But some parts are new."
It's just easier this way.
Old 09-09-2011, 07:10 PM
ZOERA-SC7XX's Avatar
If you're just gonna drive it, a std oil pump will do just fine (mine does 55 PSI cold, 45 PSI hot). If you gotta race, then go with the HV. I began with a HV, then changed to a std pump.
Old 09-09-2011, 07:20 PM
Zoera,
what that of distributor are you using? with bronze or iron gear?
Old 09-09-2011, 07:30 PM
MSD ready-to-run billet dist w/std gear. Good for up to 5500 rpm.
Old 09-09-2011, 10:31 PM
Chaplin's Avatar
You should be ok using a HV pump, but you don't need a high pressure pump.
p.s.
Don't let Rick Lake see this post.
Replica is not a dirty word.
Old 09-10-2011, 06:43 AM
ted ted is offline
For FE street drivers, my own preference is to use the HV oil pumps. The mentality for this is improved oil pressure at the lower rpms and when idling. For a drag car and reasonable clearances, I'll use the stock volume pump. If the clearances are on the wide side for a 'performance' application, then it's a HV pump again.
Ted Eaton.
Fe's are fast but "Y-Blocks" are fun when they run in the 9.60's at 135 mph.
Old 09-11-2011, 06:53 AM
undy's Avatar
With a HV pump it's advisable to have the oil drain-backs in FE heads modified to allow for quicker oil return to the sump. This will minimize excessive oil ponding in the heads, a problem with FEs.
Too many toys?? never!
