LinkBack Thread Tools Rating: Thread Rating: 2 votes, 4.50 average. Display Modes
Old 06-30-2011, 05:02 PM
Jeff Frigo's Avatar
Cobra Make, Engine: ERA 454 S.O.
Default Slight Miss at Part Throttle
427 S.O. Edelbrock heads and intake, MSD dist. Holley 950 HP carb. The engine idles perfect WOT is great, the plugs are a nice tan color, but at part throttle, it has a slight miss every 5 seconds or so.
It seems to be only coming from the right bank. I'm lost.
Jeff
“If you can make black marks on a straight from the time you turn out of a corner until the braking point of the next turn, then you have enough horsepower.”
Mark Donahue
Old 06-30-2011, 05:10 PM
FWB's Avatar
FWB FWB is offline
can you duplicate it when parked? look for fuel dribbles from the venturies in the carb.....
Fred B
Old 06-30-2011, 05:42 PM
DanEC's Avatar
Are you running all mechanical advance or do you have a vacuum advance distributor? It sounds somewhat like an over-advanced condition I had with my BB Corvette motor with a vacuum advance distributor.
A bad plug wire is another possibility. Seems they show up more under light load and idle than any other time.
Old 06-30-2011, 06:52 PM
Jeff Frigo's Avatar
I would have to say, no but I will try.
Jeff
Mark Donahue
Old 06-30-2011, 06:53 PM
Jeff Frigo's Avatar
No vacc. advance. All of the plug wire are from 120 to 130 ohm resistance.
Jeff
Mark Donahue
Old 06-30-2011, 07:22 PM
Sounds to me like a slight lean condition. Try opening the idle air screws up a quarter turn after first adjusting them for max vacuum at idle.
Jim
Old 06-30-2011, 07:26 PM
At around what rpm?
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
Old 07-01-2011, 04:28 PM
Since we're all placing bets - I go with this one. I think boosters are trying to come in. A hair larger bleed would kill signal and delay it/smooth it out.
Just guessin'...
Survival Motorsports
"I can do that....."
Engine Masters Challenge Entries
91 octane - single 4bbl - mufflers
2008 - 429 cid FE HR - 675HP
2007 - 429 cid FE MR - 659HP
2006 - 434 cid FE MR - 678HP
2005 - 505 cid FE MR - 752HP
Old 07-02-2011, 04:16 AM
vettestr's Avatar
Cobra Make, Engine: Cobray-C3, The 60's body lines on todays chassis technology
Stumble or miss only at cruise or light throttle >>
I bet this is a lean condition stumble. I would ask for all the basic/normal stuff to be checked .... float level, manifold vac. OK or no leak, timing at this RPM?, total timing.
Will it clear up if you add a bit more throttle ? It's a hot rod so add more timing and fatten her up a little more, increase RPM or get on the smooth side of the cam. Drive faster !!!
Jeff Classic
Manufacturer of the Cobray-C3
www.cobrasnvettes.com
Old 07-02-2011, 06:22 AM
DanEC's Avatar
Might still be too much advance coming in at cruise. Do you have a pretty quick timing curve or a lot of total timing in the motor like 40 deg? You might experiment by pulling a couple degrees of initial timing out of it or putting in the next heavier centrifugal advance springs to slow down the curve a little. The way you describe it as - a slight miss every 5 seconds or so - sure sounds like what I experienced in my Corvette.
Old 09-12-2011, 02:32 PM
Jeff Frigo's Avatar
Solved:
The idle air screw ghost must have stoped by one night. I could have sworn I checked them, more than once. I guess not. Both screws on the right were open only about 1/2 turn. . Sett all four to a 1 1/2 turns out, runs lake a champ. Put well over 100 miles on it this weekend, never hiccuped once.
Jeff
Mark Donahue
