Old 09-28-2001, 02:19 PM
Default Drilling sideoiler passages
I have two 427 engines that have the bosses cast into the block for the side-oiling system, but they are drilled as center-oilers. Is there a shop out there that can drill the passages out and convert them to sideoilers? If so, how much would this cost?
Any help would be appreciated.
Old 09-28-2001, 02:46 PM
Try George Anderson at Gessford.
http://www.cobraengineparts.com/
Good luck,
Better to have and not need than need and not have!
Old 10-28-2001, 06:02 AM
SUPERCOBRA IF GEORGE CANNOT DRILL THE BLOCK, JACK ROUSH INDUSTRIES CAN. LOOK IN MUSTANG ILLUSTRATED, THIER IS A GOOD ARTICLE ON WHAT YOU ARE DOING SEPT. 2001 MAG IF YOU CAN NOT GET A COPY I CAN FAX YOU THE ARTICLE GOOD LUCK WITH THE BLOCK RICK LAKE HORSE POWER IS YOUR FRIEND BUT TORQUE IS WHAT MAKES YOU MOVE
Old 10-28-2001, 05:32 PM
Jeff Frigo's Avatar
Why? There is no performance advantage.
Jeff
Old 10-28-2001, 07:35 PM
In How to Rebuild Big-Block Ford Engines, Steve Christ says: "Early 427s use the same oiling system as the 390HP. This system feeds oil to the front main bearing, camshaft and rocker shafts before the remaining main bearings. This means that an oil-pressure loss anywhere in the lubrication system starves one or all of the the four rear main bearings." This is the so-called top-oiler or center-oiler block. In part, with regard to the sideoiler, he says: "This system ensures that the main - and cam-bearing bores receive oil pressure directly from the oil pump." "If you want the best block for high performance use, the side-oiler is it."
I've got a top-oiler and am generally happy with it; however, the passage above dove-tails pretty well with what I've heard in the past, which is that the side-oiler has a better oil delivery system, and, because of that, it is viewed as a better endurance engine.
TT
Old 10-28-2001, 07:38 PM
Jeff Frigo's Avatar
OK
Jeff
Old 10-30-2001, 07:29 PM
mickmate's Avatar
I have done what you are talking about. I see you're a flatlander I'm just up in NH so we could arrange a look see if you're interested. I used Grover gundrilling out of Maine and could get you his number. It cost about $600. The angle of the holes needs to be spot on to avoid breaking through to the crank case inner. If you want measurements or to swap ideas let me know.
Rick I would be very interested in the article mentioned if I could arrange a copy of it that would be helpful I'm sure. Fax # 603-745-8897
Cheers Nick Acton
mickmate
http://www.actoncustom.com/
Old 11-02-2001, 04:11 PM
Great - Thanks for the input!
Rick: I'll see if I can find a copy of that magazine - if not I'll take you up on the fax copy.
Nick: I'll be in touch to ask more about your experiences. It's good to know there is an experienced machine shop relatively close.
Thanks again
Old 11-02-2001, 05:03 PM
HI NICK IHAVE BEEN VERY BUSY AT WORK 14 HOUR DAYS IT IS FRIDAY , I WILL FAX THE ARTICLE SAT OR MON SORRY, I DID NOT FORGET, JUST TOO BUSY. I KNOW CHECK IN THE MAIL MAYBE NEXT YEAR I WILL SEE YOU AT THE NORTHEASTERN CHALLANGE IN LOUDON IT IS A FUN THREE DAYS. IT'S NOT AS BIG AS THE RUN@GUN IN ST. LOUIS IN SEPT. BUT JUST AS NICE. TALK TO YOU SOON RICK LAKE
Old 11-02-2001, 08:23 PM
mickmate's Avatar
Rick that would be great, no hurry I'm on vaca this week in Florida so I'm just checking out where EM and Finish Line are. I've met Charlie and Dan, a couple of the ERA boys, at NHIS. Always good to put a face with a name especially one to talk Cobra with. Hopefully see you at the next one,
Cheers Nick
mickmate
Old 11-14-2001, 07:11 PM
mickmate's Avatar
Rick, thanks heaps for the info, that gives some good ideas on improving the stock set up. Now to check out the boring mills locally...............so much to do not enough cash and time!
Cheers Nick
mickmate
