Old 11-07-2011, 06:28 AM
Cobra Make, Engine: factory five mkIII roadster 445 fe quick fuel 750 q series,irs
Default fe oil filter relocation kits?
does any one know if some one makes a oilfilter relocation kit for the ford fe?,i saw one on shelby's engine site but there was no price. i would need the plate that mounts to the block, the oil filter assbly and the bracket that mounts the filter assbly to the water pump. i currently have the canton billet one but in a ffr you csan only run the short oil filter beacuse of frame clearance issues.
Old 11-07-2011, 06:49 AM
Everything you need is available here: Finish Line Accessories
Old 11-07-2011, 07:10 AM
thanks for the info, do you know if the finishline waterpump bracket is steel or aluminum?, and i did not see the block adapter? who sells them and would they have a place to install a fitting for a oil press line?.
Old 11-07-2011, 07:18 AM
I think they just have the wrong picture for the Oil Cooler External Plate. The description says "This take off plate will be attached at the engine in place of the oil filter. This allows the oil filter to be placed remotely away from the block." I can't answer on whether water pump adaptor plate is aluminum or steel -- just give them a quick call at (888) 436-9113. It's only $20. For that little it would almost be worth it to just buy it and then drop it off at your favorite machine shop and have them duplicate it with your favorite metal of choice.
Old 11-07-2011, 09:17 AM
The one I bought from Finish Line is steel painted black. Not horribly thick but it does the job fine.
