Old 12-29-2011, 07:23 AM
BAsque1's Avatar
Default 427 fe side oiler puff of blue smoke
My car is releasing a puff of blue smoke in between shifts, especially 1st to 2nd gear. Thinking that the car was not used much by the previous owner that the valve seals were dried out.
I just changed the valve seals, the sparkplugs did not show evidence of fowling due to oil burning, nor we could hear any air hizzing when the pistons were filled with compressed air while changing the seals.
After a brief test drive, it is still showing the puff of blue smoke. Any thoughts what could be causing this annoying thing?
Thanks.
Basque 1
PS
I use Castrol 40 grade oil the car has 8581 miles I must assume that the engine has this mileage too, don't know from the previous owner, he bought it with this engine. The engine feels very strong not as if it has been abused.
Old 12-29-2011, 07:32 AM
Valve seals would have been my first guess. Which seals did you put back on?
My next guess would be an intake manifold gasket sucking oil...
Old 12-29-2011, 07:42 AM
Cobra Make, Engine: Lots fo different cars that change all of the time
check the intake manifold gaskets for leaks. Just a thought
Jay
ALL I WANT IS A NICE SWEET NYMPHOMANIAC DEAF MUTE THAT LACTATES TEQUILA
Run & Gun participant 1998-2005
Old 12-29-2011, 07:43 AM
BAsque1's Avatar
Tks Blykins:
I replaced them with COMP Cams stock #515-16 (JEGS). Intake manifold sucking oil? Humm this is a first for me.
Tks
Lou
Old 12-29-2011, 07:51 AM
BAsque1's Avatar
Tks Jay:
That's two people telling me this I guess it is a viable option. Love your wish list line LOL
Old 12-29-2011, 07:55 AM
BAsque1's Avatar
How do I test for the intake manifold bad gasket whicj might be sucking oil up?
Old 12-29-2011, 08:48 AM
xlr8or's Avatar
Not much of a test you can do for that. Just pull it and replace the gaskets.
Old 12-29-2011, 09:08 AM
Valve guide wear would be my next choice.
Take the car up a long hill then turn around and have someone follw you while you head back down. Put the car in fourth gear, around 65 mph should do it and let off the gas and let the compression slow you down. Did your buddy see any smoke coming out of the side pipes? If so, valve guides and seals would be the place to begin.
Old 12-29-2011, 09:46 AM
RACER X #99's Avatar
I once had a leak in the push rod holes in the manifold. There was a porous spot in the casting and it was sucking oil right into the intake passage. I put a sleeve in there and the smoking went away. This was an original Sidewinder manifold.
SAAC member and supporter
Club Cranky charter member
Old 12-29-2011, 01:52 PM
If you have a single plane intake, you should be able to pull the carb and see all the way to the gasket (at least the center four cylinders). Well, you can with a SB. Maybe not with an FE. Brent would know for sure.
If not or if you have a dual plane, there are small cameras that can be slid in to see. You may find a mechanic that doesn't charge too much to take a look. You might be able to fish a clean white rag in and pull it out to look for evidence of oil getting into the port.
Otherwise pull the intake. Kind of a big job on an FE, so finding evidence before pulling it sure would be nice.
PS
If it puffs blue, when you start it after setting overnight, that is typically a sign of valve seals. If you are seeing this, then maybe the new seals do not fit correctly or are of poor quality. Again a camera would show oil laying on an open intake valve.
Old 12-29-2011, 02:04 PM
BAsque1's Avatar
Hummm all viable suggestions, the seals have been done not the valva guides. I will do the downhill test and and another friend suggested a vaccum test as well. Will keep you fellows posted of the outcome. I hate to think I have to repair this engine$$$$$$$$$$$$$$$$$$
Old 12-29-2011, 09:49 PM
Cobra Make, Engine: Genuine original Unique MotorCars 427 S/C, with a Genuine original Ford 427 Side-oiler.
Send a message via Yahoo to Cobranut
Poor ring seal will also cause smoke under decel. Under high vacuum any path for oil to leak into the cylinder or intake will cause smoking.
Old 12-29-2011, 10:03 PM
Pressure check the intake. It's a little work - but very do-able in your home garage.
You'll need to remove the rocker arm assemblies so that the valves are all closed. You'll need to remove the carb & make up a block off plate for that flange - with an 1/8NPT threaded hole in it. You'll need to plug/block off all the vacuum hoses.
Now take a common pump type radiator pressure tester and pump 10 pounds or so into the intake through the threaded port in the carb flange plate. If it leaks down some careful listening and soapy water solution will often pinpoint the location.
If the valves are leaking you'll hear it in the exhaust or crankcase & the test won't work. But if thats the case you'll be taking it apart anyways....
Survival Motorsports
"I can do that....."
2008 - 429 cid FE HR - 675HP
2007 - 429 cid FE MR - 659HP
2006 - 434 cid FE MR - 678HP
2005 - 505 cid FE MR - 752HP
Old 12-30-2011, 03:38 PM
tboneheller's Avatar
If you sucked a Smurf down the carb, it will cause blue smoke. LOL!!
Old 12-31-2011, 02:21 PM
BAsque1's Avatar
That is do freaking true!!! LOL Why I did not think about that geesh.
Old 12-31-2011, 04:14 PM
Dingocooke's Avatar
Cobra Make, Engine: KMP180 with 428FE and Crendon 427 with Southern Automotive 462 side oiler
Default Different perspective.....
You can buy an awful lot of oil for the cost of new guides, gaskets etc etc if it's just a tiny puff of smoke on start up and gear change, and not smoking at idle like an old poker player, then I would just enjoy driving the car as you say it drives really well??
Regards, Steve
We're not here for a long time, we're here for a good time.
My Gallery
http://www.clubcobra.com/photopost/s...0&ppuser=28157
Old 01-01-2012, 06:25 AM
undy's Avatar
I've got all the blank-off plates to pressure check the intake (and engine) and will loan them out. I've done this for other forum members. You just have to pay shipping there and back.
I've got a Dove intake so pressure testing is a prerequisite...
Too many toys?? never!
Old 01-01-2012, 07:38 PM
After all the hell you went through you probably outta be charging a hefty rental and consulting fee for those tools.
Old 01-02-2012, 06:27 AM
undy's Avatar
Knocking on wood... The KC 482 has been rock solid since. Barry_R was champs in helping me through the whole process.
Old 01-05-2012, 12:01 PM
Danr55's Avatar
Hey you guys.. be advised that Smurfs are no longer EPA approved additives.
Dan in Arizona
CCX3209
