Old 01-18-2012, 04:43 AM
Cobra Make, Engine: factory five mkIII roadster 445 fe quick fuel 750 q series,irs
Default 445 fe weight?
i want to pick up my 445 from the machine shop and i was curious if i could pick it up with my jeep cherokee. would any one know what the estimated weight would be aluminum heads, aluminum intake steel canton road race pan , aluminum timing cover, no waterpump or flywheel installed.
Old 01-18-2012, 05:00 AM
Avmaviator's Avatar
Cobra Make, Engine: Kirkham #647 brushed
Less then 500lbs I would say. Got ours (454) in our pick up and it was no problem at all.
Have fun!
Old 01-18-2012, 05:35 AM
jdean's Avatar
I picked up a 460 in a Cherokee, so you should be fine.
6th generation Texan....
Old 01-18-2012, 05:37 AM
Probably closer to 600 than 500 - but still no problem.
A couple years ago we used my wife's minivan to bring one of the EMC engines back to Detroit from Bill MItchell's in New York. Shoulda seen the looks on the magazine guy's faces when we loaded a complete FE through the side door - with a forklift!
Survival Motorsports
"I can do that....."
2008 - 429 cid FE HR - 675HP
2007 - 429 cid FE MR - 659HP
2006 - 434 cid FE MR - 678HP
2005 - 505 cid FE MR - 752HP
Old 01-18-2012, 05:45 AM
i brought my 342 home from work where i built it with my jeep but i think i had a hard time with the height of the rear hatch, but i was using chain on the engine.i have a carb plate for the 445 so that should lower it a bit?.
Old 01-18-2012, 06:39 AM
I've weighed a 427 with aluminum heads, intake and water pump: 520 lbs.
