Old 01-19-2012, 03:28 PM
Cobra Make, Engine: factory five mkIII roadster 445 fe quick fuel 750 q series,irs
Question ford fe distributor gears revisited
last year i asked the same question but time has gone by and i want to see if anyone sells a composite gear that would be compatible with my comp cams hydraulic roller serial # on cam is m-3202-07 and my distributor is a msd part number 85947. i really hope i dont have to use the bronze gear.
this for my 445 fe stroker.
Old 01-20-2012, 03:59 AM
Question
I e mailed tech at comp cams they said to use a composite over a bronze, but did not say who makes them or where to find one?. does any one have any idea where to purchase one.
Old 01-20-2012, 04:38 AM
Do you have the grind number for the cam? There are retro fit cams from Comp that don't need steel/bronze/composite gears.
I would just use a steel gear from MSD or Crane.
MSD 85813
Crane 52971-1
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
Old 01-20-2012, 04:49 AM
We use the Crane gear on numerous builds with any problems at all.
Survival Motorsports
"I can do that....."
Engine Masters Challenge Entries
91 octane - single 4bbl - mufflers
2008 - 429 cid FE HR - 675HP
2007 - 429 cid FE MR - 659HP
2006 - 434 cid FE MR - 678HP
2005 - 505 cid FE MR - 752HP
Old 01-20-2012, 04:54 AM
here is the grind # fb 3112r /3410b hr 112+4
Old 01-20-2012, 05:14 AM
There should be another number, like a 33-000-9 or similar.
When I order a roller cam, 99% of the time I'll order a steel core. However, I've gotten engines in for rebuilds that have had retro fit roller cams that are to be used with the factory distributor gears.
Old 01-20-2012, 05:34 AM
the part number is 33-000-9
Old 01-20-2012, 05:38 AM
Steel cam....
One of the steel gears that I or Barry mentioned will work just fine.
Old 01-20-2012, 05:50 AM
ok, thanks for the information, my only question is why does comp tell me that i can only run a bronze gear? is it because they are not familiar with the aftermarket?.
Old 01-20-2012, 05:52 AM
Not sure....but it may be because they don't sell a composite/steel gear for that particular application.
Old 01-20-2012, 04:43 PM
They only sel a bronze gear. They're not going to tell you to buy a competitor's part..
For a long time Crane was sole supplier - MSD only recently released their's.
Old 01-21-2012, 09:26 PM
Default More important to have the correct alignment
wrench87 It's all who you know. I have a composite gear and no problems. The issues are perfect alignment of distributor in block to 90 degrees of camshafts. Limited movement of bottom of the distributor housing. End play of camshaft under .003" Need thrust plate and torrington bearing to work this out. Last a good supply of oil to the gears. Either a pressure supply spray direct to locating or return oil from valley of block to location.
Have been running gear for 7 years and no problems. The only issue is cracking from heat cycles over years. Have hphv oil pump with 135-138 psi cold start running. Have to let motor oil warm before doing any thing. Gear weight is nothing, in grams. Cost was over $200.00. A good steel gear will work fine with again the same setup as above. Rick L. Ps I don't like bronze gears in my motor either. They wear out around 10K miles with even good setups. Bronze going through a motor and bearings does less damage than steel partials but still does damage.
