Old 07-08-2012, 04:08 PM
DanEC's Avatar
Default FE exhaust header gaskets
Do most of you running FE motors run exhaust gaskets or just a little high temp sealer on the flange?
Old 07-08-2012, 04:17 PM
Tom Cimino's Avatar
Cobra Make, Engine: Everett-Morrison 427SC 302 smallblock. 431 stroker in the works, tremec 3550
This is what alot of people are using. Be sure to get the correct ones for your particular exhaust port.
Remflex Exhaust Header / Manifold Gaskets
Old 07-08-2012, 04:26 PM
mickmate's Avatar
I like copper with the bead around the port.
Mr. Gasket 7164 - Mr. Gasket Copperseal Exhaust Gaskets - Overview - SummitRacing.com
mickmate
http://www.actoncustom.com/
Old 07-09-2012, 02:46 AM
undy's Avatar
Those are what I use too... and a set of Stage 8 locking header bolts
Too many toys?? never!
Old 07-09-2012, 03:07 AM
Default I have tryed both
DanEC. Dan for racing and motor repairs at the track I use the high temp red RTV. It dones a good job if allowed to cure. The matching surfaces have to be true for this to work and last. I have used and stayed with the old white gaskets from Mr. Gasket for my car. I use doubles on each side. When you get them in the bubble pack, I don't split them and but them in water and saok for 10-15 minutes and install. I don't over tighten the ARP bolts and use some anti seize on them. 25-30 ft pounds of torque taking them down like you do head bolts from the center out. Have gotten 7 years out of first set and now 8 years out of set 2. Biggest thing is having the exhaust aligned correct and the load weight split between flange bolts and hanger on muffler. After couple of heat cycles tighten them a little. I hear those Stage 8 header bolts work great. I have not used them. Rick L. Ps I have never tryed a copper gasket on a street motor and again repeated tear down of a motor.
Old 07-09-2012, 05:16 AM
Mdman352's Avatar
Cobra Make, Engine: Contemporary-427 stroker
Works for me. No problems.
Old 07-10-2012, 04:51 AM
Danr55's Avatar
I'm with Nick on this one.. as with most of them. Mr. Gasket Copper. Works great.
Dan in Arizona
CCX3209
Old 07-10-2012, 05:08 AM
DanEC's Avatar
Thanks everyone.
Old 07-10-2012, 05:44 AM
danc30's Avatar
Cobra Make, Engine: Hurricane HM1073 Keith Craft Genesis 427FE/482 CI
+1 for the remflex. 5 years and no issues.
