Old 07-10-2012, 01:05 PM
Cobra Make, Engine: Superformance /427 sideoiler
Default Best sparkplugs for 427SO
Just finished building my 427 SO.
I am looking for the best spark plugs to use?
Thanks for the info!
Old 07-10-2012, 04:51 PM
DanEC's Avatar
I don't know but you probably need to provide a little more information about the engine to get a good answer - like compression, iron vs aluminum heads, camshaft, induction system, etc
Old 07-10-2012, 05:04 PM
BAsque1's Avatar
I have a real side oiler (original) uses Autolite 45
Old 07-10-2012, 06:57 PM
Cobra Make, Engine: era 427 side oiler
Thumbs up
yep: what he said!
Old 07-11-2012, 12:48 PM
Danr55's Avatar
I've always had the best luck with NGK.
Dan in Arizona
CCX3209
Old 07-11-2012, 02:50 PM
dcdoug's Avatar
x2 on Autolite 45
www.partskeeper.com
Old 07-11-2012, 04:35 PM
Jerry Clayton's Avatar
I think back in the 60s I used Champion F9Y-----and make sure you have your plug wires on correctly---Patrick has a picture
Old 07-11-2012, 05:43 PM
Originally Posted by Jerry Clayton View Post
...Patrick has a picture
In the spirit of full disclosure, I had them in the 5-6-7-8 order for years, without any cross-firing problems at all, and then Jerry harangued me in to putting them in to the order that you see below. I always do what Jerry tells me to do.
Old 07-11-2012, 06:35 PM
If you want an FE engine to be original, set it up as Ford did it---------------
Old 07-11-2012, 06:40 PM
Yep. BTW, Jerry, did you see how our corner weight thread ended? Best way to adjust rear coil overs for proper height on my SPF
Old 07-11-2012, 07:01 PM
nope-as I stated , I would not have another response so I never followed up on any of it-----
Old 07-11-2012, 07:03 PM
Well, you owe it to yourself to read the last post by Silverback51....
Old 07-11-2012, 08:01 PM
so I spent the last hour reading thru all 10 pages--should of kept score as I went----
