Old 08-21-2012, 06:25 AM
Cobra Make, Engine: factory five mkIII roadster 445 fe quick fuel 750 q series,irs
Default 445 fe and spark plugs
just looking for opinions what is the best spark plug to run in a 445fe street engine using the edelbrock heads, 10-1 comp ratio hydraulic roller cam 750 quick fuel carb?. currently running autolite 3924
factory five mk III roadster, 445 fe stroker
Old 08-21-2012, 06:40 AM
That 3924 isn't bad and you can run it for awhile and see how it likes it.
Old 08-22-2012, 07:09 PM
Cobra Make, Engine: FFR MK III,462 FE/TKO 600, IRS w/3.27
I was running 3924's in my 455" FE and I was pleased with them. Seemed to be the right heat range and their appearance looked good once I got the correct jets in the carb.
I said "was" because it came apart on me. My next one will be a 462" FE, and I'll probably put 3924's in it.
Wideglidejoe
FFR#6143 Mk III: FE 462" w/four 48 IDA Weber's w/TKO 600 .82, IRS w/3.27, 17" Team III's w/245/45's & 315/35's. Gas N's.
Picked it up end of Aug '08
First start May 12, '10
First go kart May 26, '10
Tag & title 5-26-11, driving in gel coat
Painted Nov 2015
'05 Harley Wide Glide (60 hp stock, now 107 hp & 107 ft/lbs at wheel. Mid 11's in the 1/4 mi.)
'55 Bel Air hot rod project (WIP)
Old 08-23-2012, 02:50 AM
Default What ignition setup is in the car?
wrench87 If you are running an MSD 6-al box and coil I open the gap of the spark plug between .008-.010" larger because of the greater spark from this system. If stock with an oil filled coil, stock numbers are fine. I also run this spark plug 3924 in Shelby heads., Rick L.
Old 08-23-2012, 05:47 AM
I am running a 6al and a MSD high vibration coil, I was just running a .035 gap will i notice a difference if i increase the gap?. steve
Old 08-23-2012, 06:20 AM
Just curious.......what's your opinion of the AR3924 with the cut-back ground? Do you see any advantage to it?
Old 08-23-2012, 06:30 AM
Never tried a set back to back, so I have nothing to use as a baseline.
I mainly use Autolite plugs though, pick the correct heat range, gap accordingly, and run 'em.
Old 08-23-2012, 06:42 AM
I tried all the ProStock-style tricks-trimmed electrode and indexed plugs in the chamber. You won't notice a difference except possibly on a dyno or .005 on a time slip. It doesn't hurt anything but nothing you'll notice on the street.
Chas.
Old 08-23-2012, 12:21 PM
And the wallet. I think the short ground jacks the price by 2X!
Thanks for the input.
Old 08-23-2012, 07:42 AM
Jerry Clayton's Avatar
biggest issue with different types of ground straps is that they are on extented tip plugs------making sure that the piston doesn't hit them is vital ( indexing if necessary)
