December 2025
Old 08-28-2012, 09:28 PM
Mother's Avatar
Cobra Make, Engine: Boss Replica Motors BB 460 by New Generation Engines
Default Knowledge question
I want to build a 363 small block Ford. It uses a Windsor 351, bored to 427 and sleeved to 363. Then Z- heads from Ford, and the induction is by Inglese, with 51 mm bodies, including the computers for control. I hope to use a roller cam, and the long block Ford 6007 crate with the z cam. From what I have been reading, this is doable for around 21,000 Cdn. McCloud nilon clutch, quicktime bell housing, and a Temec TKO 600 with a .82 fifth gear. The rear end is a Kurrey 9 inch, with 3.70 finals, and an Auburn ratchet spool, with Strange tapered axles. The unit will need a 17 inch pin drive to mount a 335 35R/17 tire with a maximum tire height of 26 inches. A floating 4 link set-up, and coil overs. The 4 inch tube frame will have the strength to hold it, without twisting the frame into a pretzel.
The engine will produce 500 plus HP, and a max RPM of 6500. Power range kicks in about 4500. Anyone know a builder in Southern Ontario Canada who can build a reliable engine like I want built??
