Old 11-06-2012, 03:56 AM
Danr55's Avatar
Default I Need Suggestions
I'm driving a Contemporary with a FE motor and very little clearance under the hood. Right now I have a Sterling and Hellings air cleaner because I can't fit anything else over the Holley 3031 carb. I'm looking for suggestions for an air cleaner that will fit down over the carb and still have clearance under the hood. You guys have not let me down in the past and I'm sure you won't this time.
Dan
Dan in Arizona
CCX3209
Old 11-06-2012, 04:09 AM
Tommy's Avatar
Dan,
I don't have your solution, but I do have one thing to keep in mind as you search for one. People often focus so much on the size of the air filter that they forget to consider the size of the gap between the top of the carburetor and the top of the air filter. As that gap gets smaller, there is less space for the air coming through the air cleaner to be drawn into the carburetor. This can limit air flow as much as a smaller air filter. This is particularly important on large, high performance engines.
Tommy
Previously owned EM Cobra
Old 11-06-2012, 04:19 AM
mickmate's Avatar
Hey Dan, Michael Bernica came up with a low profile air cleaner base on here that fits the Xtreme air cleaners. I just put one on a CCX.
You can see there's a small gap between hood and air cleaner.
mickmate
http://www.actoncustom.com/
Old 11-06-2012, 04:30 AM
kevins2's Avatar
Originally Posted by Tommy View Post
Dan,
Drop base filters create this situation. ERA provides a 14" drop base filter with the center plate that fits on the carb detached from the base. You then measure the clearance you have (putty works well for this), leave 3/8" clearance for engine torque and then weld the plate to the base at the highest point. This gives you a custom fit with the largest gap possible.
Kevin
Old 11-06-2012, 09:37 AM
Try one of the L88 carb bases, they are as low as a Holley can permit without mods.
Ken
Old 11-06-2012, 11:38 AM
RodKnock's Avatar
I wonder if Bernica still has these available?
Old 11-07-2012, 03:42 AM
Cobra Make, Engine: AC cox 2699 roadster Riverside FIA RSR2001
See if this works for you Dan. Distributor also plays a role.
They claim better H.P as well, which was also a concern of mine.
If you are using a turkey pan Nicks looks good but possibly a bolt instesd of a wing nut?
Like to see your solution please
Ross
Old 11-07-2012, 03:45 AM
Deprecated Browser Error
Hopefully this link works
