Old 01-07-2013, 12:53 PM
Cobra Make, Engine: Dax Tojeiro, 450bhp 383 ci Stroker, Tremec TKO and Contemporary CCX, Big Block Ford, old school.
Default FE and Holley Carb Queries
Hi Guys,
more queries for you.
I have a Holley 4150 currently mounted the other way around from the norm ie vac pipe to PCV is at the front not the back.
I have this way around because my car is right hand drive and it made the throttle easier to set up. I don't believe this is an issue?
Any way the carb is tilted slightly forward so should I fit a wedge plate to bring it level?
Also do FEs usually need a thermal spacer to stop heat soak into the carb?
I decided not to fit my turkey pan.
Kev Davies, Wales (UK)
CCX-3-4028.
445 ci Ford FE
