Old 08-11-2013, 12:49 PM
Cobra Make, Engine: 428
Default How to vent crankcase with Webers?
Any ideas on how to adequately vent my 428 with Webers on a BT manifold? No vacuum port so PCV is out. I guess I could go the road draft tube (if I can find one). Breathers on each valve cover adequate?
Old 08-11-2013, 01:20 PM
I feel the need for speed
Default Venting crankcase with no vacuum
I had EFI set up for several years which left me with no vacuum for brakes or to ventilate crankcase. I hooked up a pump to turn on with the ignition and mounted the pump up under the wheel well. The pump hooked to the passengers side vent thru the valve cover. I am now converting back to carbs and have the pump I used for all those years. I will give it up for the cost of shipping if someone wants it.
Mike
Old 08-11-2013, 02:43 PM
Cobra Make, Engine: Contemporary Cobra
Default Rear breather
Try Carls ford parts or Precision Oil Pumps....$80.00 polished
Jon
Old 08-11-2013, 04:11 PM
Thanks for the tip.
