Old 09-17-2013, 01:05 PM
Default A Valve Train Surprise
You never know when the next gremlin will sneak up on you. Two days ago I removed the valve covers of my engine for a quick periodic inspection.
While checking rocker arm clearance, one jam nut on the rocker adjuster was a little resistant. I had to apply very slight pressure to get the wrench on and then wiggle it to remove it. Odd. Moments later I used a torque wrench with socket to finish the adjustment. I had to wiggle the socket to get in on the jam nut. Now I was curious. Grabbed a flashlight and did a close up inspection. I could barely see the reason for the wrench's resistance to go on.
The photo is of the suspicious jam nut that I forced onto a tapered punch so we can all see the surprise. I'm glad to have found this gremlin early.
Old 09-17-2013, 01:47 PM
cobrakiwi's Avatar
Hi
Very good catch, time for a new set. I would replace them all.
Lotto ticket time for you I think?????
Old 09-17-2013, 02:00 PM
Nice catch pal. I'd check the lash on all when you're replacing the jams.
Once I found a broken flat wound damper between the valve springs that way. Very hard to see unless you specifically look for damage such as this with a strong light or disassemble.
I was lucky.
-and stop bouncing off the rev limiter!
Chas.
Old 09-17-2013, 02:54 PM
Originally Posted by cobrakiwi View Post
Hi
Yep. The broken one is an original nut that came with the Erson rocker set that's on the engine. As Erson is no longer, I called T&D and their set of 16 nuts will be on my front porch tomorrow.
Then back to trippin' the rev limiter.
