Old 11-16-2014, 08:37 PM
Cobra Make, Engine: Everett Morrison/Side Oiler
Default 427 FE question
I am in the process of rebuilding my engine for my Everett Morrison AC Cobra. After looking at my ford original cast iron engine block, it has the side bolts for the mains, screwed in large freeze plugs, and next to the water pump on the upper right had side it is stamped 352. From what I have read about this block, no hydraulic cams can be used on this block. So am I correct in assuming a hydraulic roller is out of the question?
Old 11-17-2014, 04:00 AM
Take a picture of the rear of the block for me and I'll tell you for sure....
But no, if it's not drilled, then you can't run a hydraulic flat tappet or roller either one.
Old 11-17-2014, 06:23 AM
Neutral
I'm not to the point of access to this yet. I think you mean, by the pic of this url. Ford 352, 390, 406, 427 and 428 Engine BlocksThe drilled passages to feed the lifters. I guess there is not other way with any numbers?
Old 11-17-2014, 06:29 AM
I wouldn't trust the numbers. You need to put eyes on it yourself. These blocks are 50 years old and anything could have been done to them in that amount of time.
Old 11-17-2014, 06:38 AM
I get your point.
Tom
Old 11-18-2014, 08:22 AM
Default Date codes....maybe
Yes, in the picture in the link you provided, those are the lifter oil galleries that must be drilled for hydraulic lifters. As for other numbers, look at the third picture in your link. Note that the block is upside down, oil pan and filter adapter removed in that picture, but that casting date is still accessible with all that in place, just more difficult to see. That date code will provide at least somewhat of an indication of what to expect to see when you get to look at the rear of the engine. I have some information that indicates for 427 blocks, if it is 1967 or earlier, then it is probably not drilled for hydraulic lifters, 1968 or later and it just may be. Or if it is a service block it may be drilled.
Don’t let the sentence above the pictures confuse you, which states
The one exception was the 352 High Performance engine of 1960 which was equipped with mechanical lifters and not drilled for hydraulics.
That sentence is referring specifically to the 352 cubic inch FE engine. Note that as the caption under the first picture states
Nearly all "FE" blocks have this "352" in the casting at the front of the block, including the 427s.
So seeing that “352” on your block really doesn’t mean anything for your purposes. I have a 390 block with the “352” on the block, and hydraulic lifters.
As Brent says, the only way to be sure is to see the two bosses above the cam bearings as indicated in the picture. But the block casting date may at least may give you an indication of what you may have, and a glimmer of hope if you are wanting to go the hydraulic route.
If a man does not keep pace with his companions, perhaps it is because he hears a different rumble. Let him step to the sidepipes which he hears, however measured or far away. - H.D. Thoreau...if he had owned a Cobra
Old 11-18-2014, 10:00 AM
Bernica's Avatar
Senior CC Premier Member
If you provide the numbers on the block near the oil filter adapter, it might help narrow things a little. An example would be something like "C7AE-A"
Old 11-18-2014, 02:14 PM
55312's Avatar
I was in the same boat as you a couple of years ago. I wanted the convenience of a hydraulic cam but the 427 center oiler block wasn't drilled. I had it stroked and went with a set of roller lifters as well as roller rockers and the engine has been very reliable and very stout at 640 HP. The only drawback is having to adjust the vales every 2500 miles or so (once a summer). I was doing the valves anyway before the rebuild. It's quick and easy to do so don't let it scare you away.
Tim
Old 01-23-2015, 08:09 PM
Send a message via Yahoo to 427forme
Default HI I'm new..
My first question - has anyone or know anyone that has got a 427 from TNT Engineering off of E-Bay - his adds seem to show he builds a lot of FE's 390's, 427's and cammers, Boss 9's up to 666 cubic inches. I have been trying to find out if he's real or a scam... thanks ray
