11-27-2014, 09:44 AM
Cobra Make, Engine: Kirkham/Southern 427 SO finally on the road
Speedo cable question
I hope it's OK to post this question here, as I've great respect for the help I've gotten in this forum. (and it is a 427 SO!). Speedo cable on my Kirkham broke early this past summer. Little green painted gear in the tranny, OK. All put back together and I rerouted the cable so it only has very wide angled bends. Finally got to drive the car and the speedo worked fine, but shortly thereafter, it died.
The speedo itself (Autometer) runs CCW, I was going to disconnect it at the tranny, and, if it looked OK, spin it with a drill to see if I can isolate the problem. Make sense? Which way would I spin the drill? I might have to disconnect it at the speedo head to see. Thoughts? Thanx. Happy Turkey Day. steve
steve meltzer
"I may be wrong, but I'm never in doubt"
11-27-2014, 10:18 AM
ma
Cobra Make, Engine: factory five mkIII roadster 445 fe quick fuel 750 q series,irs
There should be a little reverse unit that mounts to the speedo, you have to remove it and clean and lube it.
I read somewhere that the cable ends are a little to long and when you tighten the cable it binds up and doesnt move freely, some have cut a tiny bit off the end so it does not bind.
factory five mk III roadster, 445 fe stroker
11-27-2014, 03:36 PM
You want to put your drill in to REVERSE when you spin it. Here, read this thread: Lubricating the Smiths Speedometer Cable To Stop Needle Bounce Even though I have a Smiths, everything still holds true for Autometers.
11-27-2014, 05:00 PM
ma
I was thinking about this, it was not the cable end but the stub inside of the reverse unit that was to long and would bind if tightened to much.
11-27-2014, 05:21 PM
It is always either:
1) the driven gear in the transmission;
2) a crack in the cable or debris in the cable causing friction;
3) a kink in the cable from too tight a curve;
4) the length of the inner cable going in to the reverser is too long;
5) the length of the drive shaft between the reverser and the speedometer is too long;
6) binding within the reverser from a lack of lubrication or malfunction;
7) the speedometer gears binding.
If the speedometer has ever worked right, then it is not going to be 4 or 5. If no changes have been made to the cable routing, then it's not going to be 3. You can diagnose 2, 3, 6 and 7 by reaching under the dash, disconnecting the cable and reverser and then spinning the cable with your fingers and spinning the speedometer by hand with the short driven shaft and then spinning the reverser by hand with the shaft. Spotting a problem with 1 requires visually inspecting the gear itself.
11-27-2014, 05:47 PM
Full Blown Member
What would make a cabke twist like a pretzel? Binding?
rodneym
11-27-2014, 06:17 PM
Originally Posted by rodneym
What would make a cable twist like a pretzel?
A craving for mustard.
11-27-2014, 09:58 PM
Senior CC Premier Member
In case you are also tinkering with speedo accuracy, here is the limited knowledge I can offer...
11-28-2014, 11:56 AM
Full Blown Member
Jamo,
Please revoke 5,000 posts from patrickt's count for this joke.
It's that bad.
Bernica,
Recently I saw an article or post online with a graph showing how the teeth affect mph, depending on a couple variables, of course. I can't find it now  but it's out there. That way there's no messy mathmadix.
rodneym
11-28-2014, 12:14 PM
Try this calculator. Or just google "Ford Speedometer Gears"
Speedometer Gear Calculator and Charts - TCIŽ Auto
11-28-2014, 04:18 PM
Bernica's calculator requires brains. Here, Rodney... use this simple chart instead.  And if you lube your cable with mustard, make sure it's the spicy brown kind, not the yellow stuff.
11-28-2014, 06:07 PM
Full Blown Member
That's a nice chart.
Spicey mustard has too many things in it.
Equal parts of lithium grease, trans fluid and good 'ol French's.
These graphite lubes are for wussies.
rodneym
11-28-2014, 07:17 PM
Interesting they don't list the "J code" orange tip gear for the toploader that I show in the pic.
11-28-2014, 07:29 PM
I ripped that from ERA's site. I don't think Bob & Peter would let you put a 3.07 or numerically smaller rear in one of their Cobras anyway.
11-29-2014, 03:05 PM
Seasoned Member
VA
Cobra Make, Engine: Unique 427 S/C, Dart 427W "Replica" Ford engine
Steve;
I had to shorten the drive on my reverser. It broke the cable just testing the speedo with a drill. Replaced the cable, good to go.
Bill
