Old 04-01-2015, 05:27 AM
Default rocker arm adjuster
Guys I am stuck, I was changing the intake manifold gasket on my cobra and found that the adjuster on one of the rockers had sheared off. The problem is I do not know where I can get another as I am also not sure who made the rockers. I am guessing at Blue Thunder but they don't look the same as the ones online.
The nut is 12 point and is a 7/16 - 20 ARP, The stud has a recess with an oil gallery drilled into it that lubricates the push-rod tip, it measures 1.142" long with a domed recess that locates onto the push-rod.
Can anyone out the identify the rocker manufacturer and give me an avenue to get a replacement adjuster and nut?
The engines a big block FE 496 Shelby America block.
Old 04-01-2015, 11:14 AM
Cobra Make, Engine: shellvalley 428 ford
Hi Lardyfella, Try here. I think the are Doug's at Precision. Link attached, I have a set new in the box for my new FE build. He makes great products.
Byron
FE Ford Roller Rocker Arms - Precision Oil Pumps
Old 04-12-2015, 11:51 PM
Byron,
Thanks a lot for your help, you were right and Doug has been great in getting me a new one on the way. Really appreciate the assistance.
Old 04-13-2015, 01:39 PM
crenbbf's Avatar
Lardyfella
I wonder what caused the failure?
Should the pin be sticking out on the other rocker?
cheers
Crendon 427s/c No68
434FE
