Old 12-16-2015, 08:20 PM
Cobra Make, Engine: Hurricane, 427/451 Side Oiler
Send a message via AIM to huskersnake Send a message via MSN to huskersnake Send a message via Yahoo to huskersnake
Default GM Alt on FE using original bracket
Will a GM CS-130D, CS-144 or GM AD series (4 prong connector) alternator fit on my '68' 427 S.O. utilizing the Ford factory C8AE-10156B and C8AE-10145-A bracket assembly with original bolts and aluminum spacer bushing? Attached is an image of an FE, not mine, with the same bracket assembly described above.
Old 12-17-2015, 05:30 AM
Cobra Make, Engine: Contemporary Cobra
Default GM Alt
I use a GM 1 wire Alt mounted low. I use a Ford bracket on top, I have to drill the Alt for the long bolt that screws into the head and then bought a after market Chevy bracket from Pep Boys for the bottom.
Jon
The Impossible Only Takes A Little Longer
Old 12-18-2015, 10:52 AM
Jon,
Thank you for providing the tip on the modification for using a GM one wire. I will be looking for that bottom bracket.
