Old 09-08-2016, 10:19 AM
Cobra Make, Engine: shellvalley 428 ford
You might try and get that cylinder as close to top dead center as you can.
Old 09-08-2016, 10:20 AM
Texasdoc's Avatar
Edit: Byron beat me to it.
Make sure you have that cylinder at TDC when you remove the springs. You will use less rope. If you have compressed air, you can pressurize the cylinder instead of using rope, but still make sure you are at TDC. If a valve slides down into the cylinder, you get to take off the head to get it out. Once you have the spring off, use a rubber band or a zip tie around the valve stem while you work on the other one. Just remember to remove all rope, zip ties, or other things before you restart it!
Old 09-08-2016, 10:51 AM
Originally Posted by ERA427 View Post
Thanks everyone. I think this gives me the right plan...
You get bonus points for replacing the valve spring and rod without removing the rocker shaft.
Old 09-08-2016, 12:08 PM
Cobra Make, Engine: ERA 427S/C w/ 1968 428 Cobra Jet Holley 750
But since you've got stock rockers, this would do the trick quite nicely:
where can I get that tool? I would love to use one like this where I don't need to pull the rockers and shaft...
I can't find any online like this.
Old 09-08-2016, 12:10 PM
Yes - important safety tip - thanks!
Old 09-08-2016, 12:13 PM
I knew you would ask that question. I have absolutely no idea where, or even if, you could find that now, but you could almost fabricate one yourself from that picture. If I had stock rockers, I would spend the time to see if I couldn't do just that, but I have big fat Erson rollers on mine.
Old 09-08-2016, 12:36 PM
Texasdoc, you typed too many words or you would have had me, LOL
Old 09-08-2016, 12:46 PM
Default The more I think abou it...
Yes, I would fabricate that tool, and I would make it out of wood, using my jig saw. Make a cardboard template that curls around the rocker shaft and "points" on to the retainer just like the picture. Then cut two of those out of 3/8" hardwood and fasten your pull handle between the two pieces so the points hit the retainer just like the picture. You could also substitute straps that go around the shaft for the fancy curled ends. That would be even easier. Come to think of it, you could probably use heavy duty zip ties around the shaft and a notched wooden pole that fits down over the retainer and it would work just fine for the few times you did it.
Old 09-08-2016, 01:16 PM
Texasdoc's Avatar
It is about quantity, not quality.
Old 09-08-2016, 01:52 PM
I think your post had both!
Old 09-08-2016, 04:16 PM
55312's Avatar
So.....hours coming up with a template of this "tool" and the follow on prototype made out of fossilized whale bone which, in turn, is scanned into a 3D printer to render the final tool to depress the valve spring ??? All you have to do is take 2 minutes to remove 4 or 5 bolts holding down the rocker arm assembly and bingo......the whole damn thing is out of the way and you can start feeding the rope! You could also borrow a compressor and skip the rope all together (pun intended). Napa has a couple different types of spring compressors for little money too. One last suggestion, cover everything up before starting to remove the valve spring. Those little valve stem keepers have a habit of disappearing if you don't handle them with a magnet.
Tim
Old 09-08-2016, 04:19 PM
Yes. Because that is our nature.
  #33 (permalink)
Old 09-20-2016, 09:26 AM
Just to follow through here...
I was able to get my pinky finger into the spark plug hole enough to feel the bottom of the vavle and confirm that it was smooth all the way around. Also put a camera/scope in there to look for signs of damage to the piston. nothing.
So I packed the cylinder with rope to hold the valve up. I removed the old broken spring (broken in two places). I used the new spring compressor but soon realize that I could not get the new spring on without removing the rocker arm. So I took that off, put in the new spring, and then removed the rope. I then put the new pushrod in, and cranked the motor to confirm that the lifter was moving up and down (it was). Then i reinstalled the rocker arm, and cranked it again with the battery, while using a compression gauge. Everything checked out okay. So I reinstalled all the plug, hooked up the coil, crossed my fingers and let it fire up. It works! Thanks for all the advice. this is an amazing forum, and great to see that the members don't get into shaming other people who are not seasoned mechanics. I learned more than i intended to on this project and thankfully fixed it without having to remove the heads. And fixed it for $18 in parts, instead of having to pay $1,000s for someone to take it apart for me.
But I still may never know exactly what caused the spring to break and pushrod to bend. At minimum, I should probably fix my flaky tach (the needle jumps all around (stewart warner)
  #34 (permalink)
Old 09-20-2016, 11:39 AM
Nice. I'm curious, when you pulled the broken spring out, did it turn out to be a single spring with a damper, or was it a dual spring (with or without damper)?
