| 29 |
2Likes
Post By blykins
Post By scootter
02-21-2017, 07:16 AM
PVC Install Question
Hi Guys,I want to install a PVC set up on my 2- 4 barrel side oiler. My questions are I would like to install a catch can with this setup and can I drain the catch can back to the oil pan? I recently installed a Aviaid 10 qt oil pan with provisions welded in the top for 3/8 and 1/2 hoses. They are blocked off now but are easily removable. Another question is where is the best location for the vacuum source (base of one of the carbs)? There is a bolt on plate at the rear of the engine that looks like a draft tube would go there. Could the PCV valve be installed there instead of the valve cover? I hate to drill into my new Cobra valve covers. Finally there are so many PVC Valves is there any particular one I should consider?
Thanks for your time.
02-21-2017, 08:49 AM
Ny
Cobra Make, Engine: Superformance #2660, FE-406
Sounds kind of like a solution in need of a problem. Unless you have reason to believe otherwise, I suspect in a properly vented system you're just not going to get much, I sure don't nor do several I know of. Mine vents to the carb vacuum fitting from the intake mounted valve and I get little or no vapor.
The older I get, the faster I was.
02-21-2017, 09:09 AM
I would not to be too concerned about running a line from a catch can back to the oil pan to return any oil. There should not be that much oil venting into catch can. If there is a copious amount, then you should have the engine looked at.
Reason: forgot something
02-21-2017, 11:31 AM
KY
If your area doesn't require the use of a PCV valve for emissions, don't run one....
02-21-2017, 01:11 PM
Ny
Your comment got me thinking, is there not some thought a PCV may help with a potential rear main seal leak in an FE based motor keeping pressure down a bit?
02-21-2017, 01:14 PM
KY
As long as pressure is vented, there shouldn't be anything to cause seal leaks.
PCV valves can cause a lot of problems: 1. It's difficult to find a PCV valve for every engine combination 2. If guys don't stay on top of things, you end up pulling oil down into the intake manifold, which causes oil consumption.
02-21-2017, 04:41 PM
Ny
Thank you, I guess I learned something today I was never really sure about.
02-21-2017, 08:39 PM
02-22-2017, 04:46 AM
Thanks everyone. Very helpful.
