Old 01-23-2002, 11:44 AM
Clois Harlan's Avatar
Default Lower Radiator Hose #
For my lower radiator hose I used the radiator hose from a 1968 Mustang CJ (part number GATES 21053). It measures 2 1/4" water pump and 2" radiator. I cut it and spliced it on a 2" piece of tailpipe bent to go under my front frame support . Hope someone can use this part number before they go and buy two hoses to make one.
The cost was about $11.00 at Bumper to Bumper Auto Parts.
"Let's roll"
"Be part of Something Good
Old 01-23-2002, 04:57 PM
Clois
I run the edelbrock pump as well but my rad stub is 1 3/4
Likely end up being a combo of rubber and steel
Tim
Old 01-24-2002, 05:55 AM
I guess as many kits as there out there and the various combinations of radiators available there is no absolute hose number.
I also use a steel tube, but before I found out the number that would correspond to my water pump to radiator combination I had to talk the guys at Autozone to let me go through their inventory with a set of dial calipers. Ended up buying two hoses at $18.00 each in order to get one. I thought these numbers might help someone else save a couple of bucks.
"Let's roll"
Old 09-01-2004, 12:51 PM
Club Cobra Member
Cobra Make, Engine: B&B 408W, TKO 600, 9" 4-link Truetrac, 13" X 1 3/8" curved vane frt disks
Clois,
What radiator are you using that has a 2" outlet?
Dave
Old 09-01-2004, 01:42 PM
Dave,
I had Arts Radiator Shop in New Jersery make me a special cross flow radiator for my Cobra. I had been running a brass 4 core radiator that was not as effective as my new one that I had built. I highly recommend "Arts Radiator" but I just checked the internet and I am not sure he is still in business.
Clois
"Let's roll"
