Like Tree1Likes
  • 1 Post By Trueoo7
Old 11-09-2018, 01:56 PM
Cobra Make, Engine: ERA 427
Default Please stand next to the dyno?
Here is a good reason NOT to stand next to an engine under test. Click on the red text "Firepunk Diesel's" link in the text.
https://www.enginelabs.com/news/the-...yno-explosion/
(If there is a better location to place this post please move it. Thanks)
BD
Old 11-09-2018, 03:02 PM
DanEC's Avatar
That's pretty wild. Good thing no one was in there nearby.
ERA 782 Running
Old 11-09-2018, 03:58 PM
twobjshelbys's Avatar
In 2009 or so we had gotten a snow that was pretty deep, the first of the season, so I decided to crank up the snow blower. It had sat over the summer, so I gassed it up and pulled the cord. Stood at the back by the handles where I pulled the starter from and started feathering the throttle. Well, all of a sudden the thing ran like a raped ape, well beyond any rev limiter top number and then suddenly BANG. The engine exploded. The cylinder wall sprayed into the sheetrock wall and the piston rod blew into it. If I'd been standing beside it I would have been neutered. It took only a few seconds for this whole sequence but it was eye opening!
CSX4005LA
Old 11-11-2018, 05:56 AM
Not that you were doing this at the time but this reminds me of an article I read that had the same outcome and pointed to real life cases where this had happened in the past. It said that the labels on small equipment advising you to never refill any engine with fuel while it is running needs to be heeded. It stated that if the fumes from the gas and/or diesel make it to the intake, it can cause the engine to rev higher and out of control. Trying to shut it down via a key or switch does not always stop it in time and the engine could explode similar to this. As you know, you need to stand beside it in order to accomplish this so that could easily be deadly.
cdnus likes this.
Old 11-11-2018, 11:22 AM
Engine had been filled with gas from before (with stabil). The area was well ventilated with the garage door open. No ether starter fluid had been used. Just went free running. Tecumseh engine.
CSX4005LA
Old 11-13-2018, 12:20 AM
I had an old timer who was used to cleaning his air cleaner with fuel in those oil bath type air cleaner. He tried it on a paper filter and put it back in his diesel and he started it and it over revved, and luckily just blew the timing belt. JD
