November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Like Tree9Likes
  • 3 Post By cycleguy55
  • 1 Post By blykins
  • 1 Post By blykins
  • 1 Post By blykins
  • 2 Post By blykins
  • 1 Post By cycleguy55
Old 02-06-2019, 07:56 AM
MOTORHEAD's Avatar
Cobra Make, Engine: KIRKHAM 427 S/C, SHELBY 427 ALUM. STROKER
Default Lsa
All other specs being equal, what would be the power difference between cam lsa's of 112 deg and 108 deg ?
"When Injustice becomes Law,
Rebellion becomes Duty." T. Jefferson
Old 02-06-2019, 11:17 AM
cycleguy55's Avatar
LSA at a Glance
Narrower LSA:
  • Moves torque to lower rpm
  • Increases maximum torque
  • Narrow powerband
  • Increase chance of engine knock
  • Increase cranking compression
  • Idle vacuum and quality is reduced
  • Valve overlap increases
  • Decreases piston-to-valve clearance
Wider LSA:
  • Raise torque to higher rpm
  • Reduces maximum torque
  • Broadens powerband
  • Decrease chance of engine knock
  • Decrease cranking compression
  • Idle vacuum and quality is improved
  • Valve overlap decreases
  • Increases piston-to-valve clearance
Source: https://www.hotrod.com/articles/cams...ted-explained/
More: https://www.enginelabs.com/engine-te...-relationship/
Dwight, Ron61 and 1795 like this.
Brian
Old 02-06-2019, 06:01 PM
MOTORHEAD's Avatar
Thanks Brian, for some reason The "Search" button in my head was "inop"
today !!
Ted
Old 02-06-2019, 09:08 PM
Gaz64's Avatar
Originally Posted by cycleguy55 View Post
LSA at a Glance
Narrower LSA:
  • Narrow powerband
Wider LSA:
I think these two are mixed up back to front. I agree with the rest.
Gary
Old 02-07-2019, 05:21 AM
I think it all depends on the application and engine. For the most part I've seen a tighter LSA make more torque, but a tighter LSA also can increase overlap, which decreases vacuum, etc.
You can't really make a generalization though that changing from a 112 LSA to a 108 LSA will get you this, that, this, and that. It doesn't work that way. It all depends on the displacement, cylinder heads, intake, rest of the cam specs, etc. You can generally say that changing nothing else, going from a 112 LSA to a 108 LSA will increase overlap, which will decrease engine vacuum, and could make the engine inefficient.
A couple of random notes....
I run a 119-120 LSA on my pulling truck engines that need to pull hard up to 8500-9000 rpm.
On a small displacement engine with a big fat intake port (think 351C or 427 Tunnel Port), a tighter LSA is necessary to make big power at all. It's not because we're trying to juggle horsepower or torque curves, but we need overlap to scavenge the intake charge.
Cobra #3170 likes this.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
Old 02-07-2019, 08:03 AM
MOTORHEAD's Avatar
Thanks to all for your input. The Hot Rod tests show the basic differences I was wondering about.
Now for the rest of the story:
When I built this engine I was camming it for Webers, and asked Barry Robotnik for his opinion and he got me a Comp hyd roller with 112 LSA, which worked well with the webers, but I had what turned out to be a sealing problem at the port head/intake junction. As a last resort,I took off the webers and manifold and installed the original holley and manifold, and it runs just fine, been using that set up for quite a while with no problems, just wondering if I was losing power by keeping the "weber" cam with the 4 bbl set-up.
Old 02-07-2019, 08:14 AM
Hot Rod tests on a SBC don't reflect everything....
Gaz64 likes this.
Old 02-07-2019, 10:39 AM
Too many variables to say. You'd have to pick apart each cam timing event separately.
I will say this: camshafts revolve around overlap. If you have too much overlap for a given displacement/cylinder head/rpm combination, then the engine will be terribly inefficient and power will be lost. Hydraulic rollers for large displacement engines typically have large advertised durations, which increases overlap. Going to a shorter LSA may hurt things. Just depends on the entire combination and the camshaft specs.
There are no general rules.
Gaz64 likes this.
Old 02-07-2019, 11:00 AM
cycleguy55's Avatar
Gary
Check the charts at the linked article. https://www.hotrod.com/articles/cams...ted-explained/
LSA Torque
101 493.9 at 4,400 rpm
107 487.1 at 4,600 rpm
113 472.4 at 4,700 rpm
Brian
Old 02-07-2019, 11:12 AM
Articles like that turn me against the internet LOL...…
Making a general statement that a 112 LSA will have plenty of vacuum and make everything work well with EFI is just a gross overgeneralization.
My 7500 rpm hydraulic roller dyno mule FE had a 114 LSA and wouldn't have enough vacuum to do squat. It all depends on the combo.
Gaz64 and moar_carbz like this.
Old 02-07-2019, 11:34 AM
cycleguy55's Avatar
Agreed. Complex subjects can rarely be explained by simplistic tables, much as complex problems are rarely fixed with simple solutions.
Gaz64 likes this.
Brian
