Old 02-18-2002, 07:27 AM
Clois Harlan's Avatar
Default What Spark Plug
What spark plug type and gap is everyone running with their 428?
"Let's roll"
"Be part of Something Good
Old 02-18-2002, 09:04 AM
Clois.
I use a number of plugs and there doesn't seem to be a difference in my 428 FE. These are my Street/Strip plugs, I use cooler plugs for competition:
Motorcraft BF-32 or BSF-42C (resister)
Autolite 35 & 34 or 45 & 44 (resister)
Champion F-11YC & F-9YC or RF-11YC & RF-9YC (resister)
Accel 378 & 375 or 675 (resister)
I use an MSD electronic ignition therefore I use 44 (street/strip) & 40 (competition) spark plug gap. If you use a point system, you'll need to use 35 & 32 gap, respectively.
Hope this is of some use to you.
Jer
Old 02-18-2002, 12:49 PM
Dave Samson's Avatar
Send a message via ICQ to Dave Samson Send a message via Yahoo to Dave Samson
Jerry,
Why open the gap so far in conjunction with the MSD ignition ?
Have you tried the smaller gap with the MSD too ?
Cheers,Dave
Old 02-18-2002, 12:58 PM
Back in Black's Avatar
Cobra Make, Engine: West Coast. 514 / 6 speed Richmond overdrive
Thumbs up The MSD has the most incredible multiple spark
Having seen the MSD active displays, with plug simulator/visible spark, I can attest that the gap can be extended to over an inch, and still look like one bad to the bones plasma discharge.
I am therefore convinced that the MSD has some major gap jumping properties...the gap can be way wider than with a standard ignition, and that means more fire in the hole. It also revs way up high and does not fail to make the 1 inch (or more) jump at those high revs, (like 10,000 rpm plus)
So my car will have the MSD works.
James Madison, father of the Constitution, said, "If Tyranny and Oppression come to this land, it will be in the guise of fighting a foreign enemy." He also said, "No nation could preserve its freedom in the midst of continual warfare..."
http://www.standdown.net/index.htm
Old 02-18-2002, 08:33 PM
Great, now someone will invent 1" gapped plugs, what next ?
Cheers,Dave
Old 02-19-2002, 06:06 AM
Default Gap?
Ok I have used three sets of plugs lately, Champion RC12YC, Autolite 985, Motorcraft ??. Both Champion and Motorcraft are the same plug based on the RC12YC, gapped at .034 ".
Yesterday I bought the Autolite 985 plugs (crossover for the Champion RC12LYC) and if I use them I will gap them at .048". I too am using the MSD 6AL box. I actually bought these by mistake and was going to take them back and exchange for the shorter gap plugs but I think I may try them with the wider gap.
The Champion RC12YC are the recommended plugs for the Edelbrock aluminium heads. Any reason I shouldn't try this other than the $1.09 per plug cost.
Clois
"Let's roll"
