Old 11-29-2002, 10:38 AM
Trans-Am Jim's Avatar
Send a message via ICQ to Trans-Am Jim
Default Oil pressure question
Got a crack in my oil cooler last time out this year. Really came as no surprise; it's as old as the car (19 yrs.) and I've had it out a few times and inadvertantly dropped it once.
Installed a new Mocal 13-row and noticed a change in oil pressure at start up and when car is not fully warmed up. Previously, it had been 80-90 lbs. at cold idle, then dropped to 60 when at warm idle, 80 at 3,000 rpm. Now, with the only change being the new cooler, it's 50-60 lbs. at cold idle, then when warm is back to 60/80.
Specifics are 65 427SO, Melling HV, Canton pan, #10 AN lines. Oil is 20/50 Valvoline VR1 dino.
I'm not concerned; mostly curious as to why a new cooler would reduce cold idle oil pressure by 30 or so pounds? And yet not change hot the hot pressure range of 60 - 80.
Anybody have an idea?
Jimbo
Old 11-29-2002, 02:33 PM
Probably flows better, thus less restriction cold. When warm, oil flows easier in both and oil pressure determined by engine restrictions.
Don
Old 11-29-2002, 04:15 PM
Cobra Make, Engine: Contemporary CCX33868 Sold. Just "playin' the boards now."
Don's probably right. I'd guess that the cooling tubes in your oil cooler are bigger than the old one or there are more of them flowing oil.
Al
"If some is good, more is better.
And too much is just enough."
--Carroll Shelby
