Old 01-16-2003, 01:15 PM
Cobra Make, Engine: ERA / nascar side oiler
Default I'm looking to buy 427 nascar
What should I look for , what concerns would you have . I know the old style valves should be changed to stainless steel
Thank you !
Old 01-16-2003, 03:54 PM
Are you looking for an actual 427 used in NASCAR or built to the same specs? Or are you looking for a high performance, correction, an even higher performance 427 SO. If you are looking for the latter there are several builders that can build FE's to your specs. Bill Parham has been working with them for over 30 years and can build you whatever you want. My dad went with him (Southern Automotive) for our 427, so he is the first name that comes to mind. I am sure other companies such as Gessford Machine, or Shelby American could build you one hell of a motor.
2500 Pounds of steel, rubber, and fire. AAAHHHH!
Old 01-16-2003, 04:09 PM
The block with the larger Crank ( C9AE-6303A ), 2lb+ (1000 grams) connecting rods
looking to compare pros to cons , hoping this sight could shed some light !
Old 01-16-2003, 04:17 PM
RACER X #99's Avatar
Default NASCAR 427
John,
Contact these guys, They probably built more 427 Nascar engines than anybody.
http://www.holmanmoody.com/
Cranky
Old 01-16-2003, 04:28 PM
computerworks's Avatar
Default How 'bout some details
John...just to broaden the scope of your question a little bit:
Can anyone itemize all the differences that are specific to a "NASCAR 427"?
Old 01-16-2003, 05:36 PM
REAL 1's Avatar
Banned
My 427SO is a NASCAR 427SO.
As I understand the differences are as follows:
Block is made with a higher nickel content for added strength.
Wider journals on the crank
Rods are beefier than even the Le Mans rods.
