Old 09-08-2003, 08:38 PM
Send a message via AIM to hdheritage97
Default Backfire trouble
OK FE heads, here's the trouble. Car runs great, a little hot, but what else is new, but when I shut it off, it backfires out of both headers. First the passenger side, then about 3 seconds later, the drivers side. Happens each time I turn it off once the car is warmed up. Any ideas as to what's making it happen ?
Cliff
" Like my Grandfather always told me, if you are truly good at something there's no need to brag, others will be sure to do that for you "
Old 09-12-2003, 12:44 PM
Nantucket427's Avatar
Cobra Make, Engine: Superformance#1325, Miller Machine FE
Default Mine Backfires too
I am running a Southern Automotive 427 center oiler with a cp 501 cam and 2X4 . The car runs around 100 c not much more but it is rich and fire burps out the side pipes if the car is hot just like yours. The carbs are to rich, putting un burned fuel into your pipes after the car is turned off, the pipes being hot fires it off. Many different reasons all centering on the carbs. Do the throttle blades close all the way at idle? Are the Power valves blown and dumping fuel into the engine? Are the secondaries sloppy and opening a little at idle/ Will the car idle? At what/ What carbs are you running? Is the timming right? Are the floats set right. You may want to look at my thread "Holleys to Rich" I am putting new holleys on this weekend. Times awasting winter is coming. I will rebuild when it is to cold to drive.
Everything has a downside, so dwell on the positives. Find humor in the tough times.
Old 09-15-2003, 07:08 AM
Clois Harlan's Avatar
Just a thought but try slowing down your idle a little. I dropped my idle to 800 RPM and eliminated my backfires.
Clois
"Let's roll"
"Be part of Something Good
