Old 09-25-2003, 09:39 AM
Send a message via ICQ to pro-st-fairlane
Default heads???
i have recently bought a set of 390 heads casting # ciae ...the valves have been taking out to 428 cj size and its been fully ported when i got them i notice that the oil pasage for the rockers was blocked off with alan head plug does anyone know why this is?
Old 09-25-2003, 11:54 AM
all the ones i've seen have those, i don't know why though.
Old 09-25-2003, 12:33 PM
Cobra Make, Engine: Classic Roadster with 427 center oiler
If you are referring to the oil passage that feeds oil through the rocker stand to the rocker arm assembly, one of the oil modifications that is done to the FE engine is to restrict the oil flow to the heads by reducing the size of that oil passage. This is done because the stock passage allows too much oil to the top of the heads and the valve covers begin to fill with oil. The oil return holes cannot keep up with the amount of oil coming into the heads.
Check the allen head screw closely to see if a small hole has been drilled into it to allow some oil through. Some people thread in a card jet. This restricts the oil but lets enough through to lube the rockers.
Do a search on this forum " oil mods". This will explain in more detail
Paul
life is short: eat dessert first !
