Old 11-19-2003, 02:52 PM
Default New Mallory Distributors
We are now shipping two new models of distributor to fit the Ford FE V8.
3255311 features a billet housing, ball bearing shaft support, a large Ford style magnetic pickup, an adjustable mechanical advance and a cap with male (HEI style) plug wire terminals. The cap is held to the distributor housing with screws rather than clips. The cap is smaller than the Comp9000 cap but slightly larger than the small traditional Mallory cap. This distributor must be used with an ignition box such as Hyfire, Accel or MSD. Vacuum advance can be added if desired.
4255311 is similar to the 3255311 but also includes a built-in electronic module (MBI) which is triggered by the magnetic pickup. This distributor can be used with or without an external box. It features an adjustable vacuum advance in addition to the adjustable mechanical advance. A lockout is included that allows the vacuum advance to be removed.
Cost depends on where you buy but the 3255311 will run about $240 and the 4255311 about $260.
