Old 02-14-2004, 07:20 PM
luke-44's Avatar
Default Correct FE Plug Wires - Buying Tips?
I want to swap out the blue wires that came on my car for black ones. Also looking for nice/tidy stand-offs to go with pent roofs.
Any do's or don'ts? Can these be bought at the local Pep Boys or Auto Zone?
I did check the search function - couldn't find this specific topic.
Thanks in advance......
Bruce
Enjoyment may be 9/10's anticipation, but that last 10% is oh so sweet....
Old 02-14-2004, 09:52 PM
Cobra Make, Engine: KMP
This question is not as simple as it may seem. Call Bill Parham at Southern Automotive.
Lew
I'm no expert.
Old 02-14-2004, 10:29 PM
CC Member / Sponsor
Original wires for the comp cars were orange.
Cubic Performance
HiTech Legends
https:HiTechLegends.com
Evolve Lubricants
https://evolvelube.com/
Old 02-15-2004, 03:47 AM
427 S/O's Avatar
I picked up the MSD 'do-it-yourself' kit,
a little time consuming but you tailor each wire and a have a neat clean setup. Kit comes with everything except a vise and razor blade, I like the gray wire, it dosen't stand out and make the engine bay look like a coloring book.
Perry
Old 02-15-2004, 06:45 AM
Bud Man's Avatar
Cobra Make, Engine: Former Owner/Builder of KMP142 427 Sideoiler, Tunnel Wedge, Aluminum heads, etc.
Luke:
Important to keep in mind that if you are running an MSD type ignition box a spiral wound wire - not solid core - is mandated. Aftermarket wiring was one of the few concessions I made to underhood authenticity on 142. I finally settled on Accel 8mm Superstock black wiring.
If you use the stock plastic standoffs on your pentroofs, you will need to radius the openings a bit to accommodate the 8 mm as they were designed for the stock street 7mm wires. My original MSD wires were 8.5mm and were just too thick.
Bud
Old 02-15-2004, 07:07 AM
CC Member / Sponsor
I have lost the part number. But one year (87?) the 5.0 liter Mustangs used 8 mm clip on wire seperators that will work perfectly on a Pentroof valve cover.
Cubic Performance
HiTech Legends
Evolve Lubricants
Old 02-15-2004, 07:08 AM
CC Member / Sponsor
Taylor wires are also very nice.
Cubic Performance
HiTech Legends
Evolve Lubricants
Old 02-15-2004, 08:19 AM
Rick Parker's Avatar
Here is an example of the Autolite wire that was used on many of the Ford HiPo cars of the 60's & 70's. (Ebay #2457916424, sorry??). It was not uncommon to buy the wire, the connector ends and fabricate your own custom fit set. Now the trend is to purchase a ready made set.
Rick...................
Old 02-15-2004, 04:02 PM
luke-44's Avatar
Lew, Perry, Bud and Rick...thanks for all the comments...I knew this wasn't as simple as first appeared.
Tom - first of all, sorry I didn't say hello last week when I was on the shop tour with David - you seemed prettty intensely deep in thought - David said it was the balance bar problem with the master cylinder redesign you were contemplating , so I figured I'd leave you be.
I checked the Taylor wire website ...I do like the molded sparkplug boots, but it seems they offer red, and not orange - is this what most people substitute for the original orange?
I am running MSD, so I assume the correct wires I am looking for are
a) spiral wound wire - not solid core
b) 8 mm thickness
c) in orange.
Thanks again....
Bruce
Old 02-16-2004, 08:25 PM
Keep #7 and #8 wires seprerated in the run from cap to plug as much as possible .A sempathetic or parralel induction could #8 to fire with #7
Mike H
