Old 03-08-2004, 07:27 AM
MIKE SCHULZ's Avatar
Cobra Make, Engine: Contemporary 427 CCX 3627 ,TKO 600 RR,TWM 58mm DFI
Smile F.E Drill Bit Test.....??
Gentlemen;I have read several posts but none seem to tell me enough information about how to perform this "Drill Bit Test" - so next time I am at the junkyard on my back covered in Goop - I can be reasonably sure that the block I am looking at could have the thicker cylinder walls. I have 2 D4TE blocks with the webbing and I punched out the freeze plugs.Can anyone inform me as to how I go about doing this??.....Thanks!....Mike Schulz
Old 03-08-2004, 11:14 AM
Club Cobra Member
Send a message via AIM to K.Wilson
Mike,
The process is quite simple, but you will need a good drill index with all sizes down to a 64 inch and letter drills too; plus a good electronic caliper if you want to get good results.
As an example (no specific engine):
With the head off measure the distance between the bores at the most narrow point for the cylinders you will be measuring.
Then find the drill bit that most tightly fits between the cylinders ( the one that just "wiggles" in) using the drive end of the bit not the cutting end.
Take the measurement between the cylinders minus the drill bit size, divide by 2 and you have an approximate wall thickness.
Example: distance between cylinders .380 inch minus drill size 3/16 (.187) equals .193 divided by 2 equals .096 cylindar wall thickness.
Now the bad news, the walls could be shifted and one side could be less and the other side more, or they could be tapered etc. so the measurement is not exact. But for a simple evaluation of a block it is a good indicator.
Keith
Old 03-08-2004, 12:54 PM
Thankyou Sir; That method makes sense!.....Now away I go to get covered in "GOOP!"
