Old 03-21-2004, 07:22 PM
Cobra Make, Engine: FFR 428PI Toploader
Default Any FE experts in Cincy area?
My clutch won't engage. I have the master and slave cylinders mounted, bled,etc. The slave cylinder travel is fine but the clutch fork is binding up. I think I might have the fork mounted improperly to the FE bellhousing?
any suggestions before I have to rip this apart again? would like to see if someone is close could come over and take a look?
thanks
"Any man that loses his spoon spends a night in the box"
Old 03-21-2004, 07:54 PM
Cobra Make, Engine: I drive and test my customers
Give me a call on Monday and maybe I can help. We have done a few FE Cobras in our day, Eric (513) 738-5001
Eric H.@ Performance Engineering
Old 03-22-2004, 04:20 AM
Few questions for you....
1. How does the clutch fork sit? Does it point towards the front of the engine?
2. What mount did you use? Did the clutch fork clip in, or does it pivot on a ball?
3. Did you grease the input bearing retainer where the throwout bearing rides?
4. Does the clutch fork move back and forth freely without the linkage on it?
5. Are you sure you're using the right setup for the bellhousing?
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
