  #321 (permalink)
Old 07-20-2004, 07:29 AM
Originally posted by steelcomp
Starting at 70? What's that all about?
You sure put some narrow limitations on your performance. Street racing, straight line, top end only, from 70! Come on. Where's the challange?!
I prefer to smoke their asses to the corner, in the corner, through the corner, and out of the corner, and so on. I don't know what part of the midwest you are in, or what your driving conditions are. We have some AWSOME roads here in CA with miles and miles of every turn and terrain you could imagine, mixed in with mile(s) long straights. That's my idea of what a cobra is for. But to each his own.
I know what a Hyabusa is. Let's just say, I'm skeptical. HP to weight ratio dosen't work out in your favor. BUT...if you say so.
The starting at 70 mph was a example. I was simply stating that at 45 mph+ speeds the big blocks CAN put the power to the ground. There are many roads on the outside of the city were there are hundreds of miles of awesome roads were the view is breathtaking and the roads do about anything you would want. I will not "race" someone through these conditions, however some of the Cobra drivers (including myself) will go cruising single file and "race ourselves". I am not qualified to, nor are the other drivers qualified to race each other at high speeds through the curvy style roads. The crotch rocket boy's do that, and in fact they might have 30 bikes flying through the turns side by side. I don't think they are on a death wish or are looking forward to a wheel chair, but that's 16 - 20 year olds for you.
As far as the Hayabusa/GSXR1000 goes, they are high 9 second 1/4 mile motorcycles and my Cobra does a mid 10 second 1/4 mile with drag radials. I lose to them on a drag race from a standstill because of traction conditions (I think with 325/50/15 slicks it would be another story), however from 45+ launching speeds I have no issues other than objects in the road. A crotch rocket even at 45+ mph can get out of control and have wind conditions come into play.
  #322 (permalink)
Old 07-20-2004, 08:05 AM
Scott
The weights on the corners are just a starting point..... and you need a starting point.... but once you put the car on the ground and hook up the sway bars and drive it .....
The tire temps will tell you what to do to the Spring once you come off of the track.... they will also tell you what to do to the camber or toe.....
And after a short period of time you will know what to do by the way the car is handling....
Morris
Morris
  #323 (permalink)
Old 07-20-2004, 08:17 AM
Steelcomp:
I purchased the Superformance Cobra because of how easy the car is to drive. Even with a big block you can power through a corner and the car will come out of the corner in a straight line. When it loses traction it just does a little wiggle and goes perfectly straight . I would have to say this is due to the endless Superformance research and development and the Olthoff's racing development.
  #324 (permalink)
Old 07-20-2004, 09:01 AM
Thanks Morris,
Last year at Gateway was the first real test for the car. Prior to that it had only seen the street, so "testing" was of the "seat of the pants" variety.
I went to Gateway with .9 neg in front and .4 neg in rear, which is a lot less negative camber than is usually recommended for C4 vette suspension. Also, I reduced the amount of rear camber gain to keep the contact patch flat when the rear squats under acceleration, per D. Guldstrands recommendation. Toe is 1/16 in because it just "felt" best.
At Gateway temps were 150 across the rears and 145 across the L. front, the right front was 10 degrees hotter on the outside because of turns 3 & 4 of the oval.
What does this say? Why do you think the temps are low? Not driving fast enough?
Scott
  #325 (permalink)
Old 07-20-2004, 10:02 AM
Hi Scott
I would think that the tires are old .....anything past 3 heat cycles is hard to get the tires up to normal range.....
Normal range is 200-210 degree's.... were the tires radial or bias??
Also what was the starting air pressure and ending air pressure.... also were you using Nitrogen... instead of air...??
Also I appologize for discussing suspensions on a motor thread...
Morris
Morris
  #326 (permalink)
Old 07-20-2004, 10:56 AM
Great Asp's Avatar
Cobra Make, Engine: SPO 2715
Default Oh Bandit......
I am not going to be in some "measly" 550 horsepower small block Cobra
"You talkin to me?"
LOL
Hey, come on. There is always someone faster. On the street, or on the track. You want to beat a motorcycle? go for it. My car goes a legit 11.95 in a 1/4 mile, with Track Claw on street tires. (and then I was asked not to run anymore) And in an open roadster, the trap comes up fast. Power to weight ratio is right up there with any power added street car that can run "stoplight to stoplight". (I think we all know what I mean, that's why there is a true street class).
550 hp in a 2600 lb car is not "measly", please. A Pinto station wagon is measly.
12 second street car is fast, but there is always someone faster. You might like the movie "The Fast and the Furious", they have "8 second" street cars in it.
And for the record, KC has to be getting a chuckle out of this conversation. You can always go faster, nerves and money is all it takes....
Eric
  #327 (permalink)
Old 07-20-2004, 11:33 AM
Bench racing at it's best:
Hey Eric, I ran 11.90 ET...... ERA wins again.
  #328 (permalink)
Old 07-20-2004, 11:58 AM
Great Asp's Avatar
Default LOL
Yeah, yeah, yeah....
Didn't you read what I said?.....lol ALWAYS someone faster.
ERA is a nice car, without question. It was the first car I considered when i was buying my first. It is a very correct, and well made car.
Eric
  #329 (permalink)
Old 07-20-2004, 12:21 PM
Big Block 10.47 ET with the BF Goodrich drag radials.
These days if you only have 550 "measly" horsepower, the only car you are going to beat is a Pinto station wagon.
  #330 (permalink)
Old 07-20-2004, 12:25 PM
Dam! I'll need some drag radials to get into the 10's.
  #331 (permalink)
Old 07-20-2004, 01:50 PM
Great Asp's Avatar
Default what????!!!!!
Only a 10.47?????? LOL
You need to get out more often. Outlaw Street class runs 8-1/2 to 9 seconds on drag radials, (right around minimum 3,000# vehicle weight) and with a "measly" 331 ci motor for example. You must be living under a rock!....lol I can't believe you don't drive a Top Alcohol to work. Lets face it, you might see John Force on I-70, and how bad would it be if he beat you from 70 mph????
IMO, 400hp on the street in a 2500 lb car will keep you smiling like the Enzyte guy. And for you Bandit, here is the link
http://www.enzyte.com/
I think a BBF is great, but there is nothing wrong with a SBF in a Cobra, geez.
I know I can beat a Pinto, I just don't want to run into the rear of one!
Eric (He who likes all blocks Ford) Brown
  #332 (permalink)
Old 07-20-2004, 02:00 PM
"Keep you smiling like the Enzyte guy"
-Priceless, Eric... Priceless.
I will be using THAT one at work!
J.P.
Ohio Cobra Club
Token Gashole
  #333 (permalink)
Old 07-20-2004, 09:48 PM
Asp (Eric)...you took the words right outa my mouth. I'm crackin' up!!!
  #334 (permalink)
Old 07-20-2004, 09:59 PM
Hey, my first car was a 69 Ranchero with a factory installed 428 SCJ, and functioning ram air. This was the baddest ride around in those days. Dad tweeked it a little and I took it to Irwindale Raceway at one of their Fox Hunt nights ( all ladies got in free) and ran it during the "run what you brung". We had two man hole covers in the back, and GoodYear Blu Streaks. With a 3:89 LS rear, C6, and factory exhaust (and 90 lb int.), that thing ran an 11.88 at 124 mph!! Still got the slip, somwewhere.
That FE ruled!!
Thanks Pop.
  #335 (permalink)
Old 07-20-2004, 11:58 PM
OH,,, so THATS what Enzyte is. Never needed anything like that myself......
"Bench racing" (or is it, bed racing now?) comes in all kinds of forms you see.
  #336 (permalink)
Old 07-21-2004, 12:51 AM
HI Cobra's Avatar
Hey Ernie,
That Enzyte gives a whole new twist to the Carol Kai bed
racing here on Oahu!
Flip
  #337 (permalink)
Old 07-21-2004, 05:09 AM
To All,
I'm going to take this opportunity to hijack my own forum - sorry!
As some people know, I'm turning my long time passion/hobby into a business.
For those that don't, the business is based on locating collector, museum quality (really, really, nice units) Muscle, exotic and specialty autos. Been doing this a long time for friends, friends of friends, then aquaintences, so-on, so-on. I'm told so many times to open a business, well, I'm going to give it a shot.
Anyway, for those who may be interested,
The company is:
"CONCOURS CONCIERGE SERVICES"
provided by: B & B Automotive
* We also offer brokerage, aquisition, and consignment of a single vehicle or an entire collection. We will provide auction representation, 3rd party negotiation, and we can even facilitate a dealer purchase.
Warmest regards, Bret Ewing
610 799 5847 / 610 417 4352 / E-mail - bbauto@ptd.net
B. Ewing
  #338 (permalink)
Old 07-21-2004, 07:45 AM
Cobra Make, Engine: ERA 377 - 428SCJ
Default Shelby Aluminum
It's news to me but good luck Brent. Sounds like a very interesting way to spend your work days.
Terry
Terry
Encino CA
ERA 377
428SCJ
  #339 (permalink)
Old 07-21-2004, 09:11 PM
Cobra Make, Engine: CSX4761, KCR Shelby Alloy 496,760hp
Send a message via AIM to misfit41
Good Luck Brent,,take it from me,,the day you start to enjoy your work is the day you stop working,,I make much less money now than when I worked 14 hr high pressure days,but I could have never afforded 2 cobras then,so go figure,,, it's all in the heart,,
best of luck,,Tim
Tk
"this whole Adult thing just isnt working for me "
  #340 (permalink)
Old 12-31-2004, 07:11 AM
Cobra Make, Engine: CSX4819, 427 all aluminum
Send a message via AIM to CWCobra
bret e ewing,
I have just ordered my Shelby CSX4819 3 weeks ago. You are CSX4802. May
i ask how long you have been waiting and what is your experience with Shelby? Con
CWCobra
