Old 05-15-2004, 02:53 PM
NJ2000R's Avatar
Cobra Make, Engine: ERA (SOLD) now just a bunch of mustang cobra's
Send a message via ICQ to NJ2000R Send a message via AIM to NJ2000R Send a message via Yahoo to NJ2000R
Default camshaft end play?
what is the normal camshaft end play supposed to be in an FE motor?
2000 Cobra R #262 of 300
1995 Cobra R ex-IMSA race car (Hacker Express #00)
1993 Cobra R ex-Speedvision race car
2006 F350 Diesel 4x4 Crew Cab
1967 ERA Cobra (SOLD)
1968 Mustang Coupe 428 CJ auto
1966 Fairlane 289 auto
1970 Cougar 351 auto
1976 Bronco
Old 05-15-2004, 04:17 PM
Cobra Make, Engine: Classic Roadster with 427 center oiler
NJ2000R
According to Steve Christ's FE book, crankshaft end play should be 0.004 - 0.010, with 0.014 inches maximum. This is for a stock FE. He says "less clearance is desirable" (stay towards the 0.004 end of the tolerance) especially for racing engines which should have a tolerance of 0.004 - 0.008 inches.
Hope this helps.
Paul
life is short: eat dessert first !
Old 05-15-2004, 08:27 PM
NJ2000R's Avatar
Thanks Paul....I dont have any books with the specs, and I have a 390 motor in my 66 fairlane squire wagon that was making a ton of valve train noise, so I pulled the valve cover off, and there was a pushrod hanging out in the lifter bore, number 6 cylinder, but no lifter in sight.... after I pulled the pushrod out, I got the shop light and saw the lifter in the valley....got a magnet, and pulled pieces of it out....a broken lifter - make that shattered lifter - never saw that before....pulled the intake, got about 4 top pieces out and the plunger, but the bottom of it is probably down in the pan....I noticed the lobes were offset from the lifters, so I stuck a screwdriver down in the distributor hole, and the cam has about 1/4" of end play, so I'd say the cam bearings are shot....time for this motor to come out for a rebuild....
1976 Bronco
Old 05-18-2004, 04:56 AM
NJ2000R Blueprint motor cam shaft end play, iron motor is .003-.005. Ford racing makes a thrustbearing and retainerplate part #M-6269-A460. This is for steel camshafts. Hope this helps Rick Lake
