November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 05-28-2004, 05:02 AM
Cobra Make, Engine: 428 dual quad
Question What FE aluminum intake do I have?
I currently have a FE aluminum intake for sale on ebay (auction ends June 1, 2004) but I don't know exactly what I am selling. The is the FOMOCO logo stamped on it, the ford firing order, and a code CK8. That's it. It appears to be a single plane manifold. Can anyone identify what this is called and when it was made? Thanks
Old 05-28-2004, 05:56 AM
Woodz428's Avatar
Cobra Make, Engine: Coupe,Blue w/white stripes SB; Roadster, Blue w/white stripes BB w/2-4s; SPF installer/Hot Rod-Custom Car builder
Arrow
A listing # would be helpful. I searched under FE and FE intake and couldn't find it.
WDZ
Old 05-28-2004, 06:32 AM
chuckbrandt's Avatar
Club Cobra Member
Cobra Make, Engine: ERA # 665, 390 (to start with) Toploader
Default I couldn't find it either.
I'd be real surprised by a factory single plane intake other than a tunnel port or something.
Chuck
Build website at www.chuckbrandt.com
Old 05-28-2004, 07:00 AM
Cobra Make, Engine: ERA 427 SO
Joe,
My book only lists three single plane factory manifolds:
C8AX-9424-B - 4V single plane for a 427 Tunnel Port
C8AX-9424-A - 8V single plane for a 427 Medium Riser
C7OE-9424-A - 8V single plane for a 427 Tunnel Port
No listing for CK8. FWIW, my manifold has no part number, just the FOMOCO oval logo and the firing order...
Photo maybe?
Ken
Old 05-28-2004, 07:51 AM
Woodz428's Avatar
Arrow
I was thinking the CK8 might be a casting date code.
WDZ
Old 05-28-2004, 08:50 AM
avanti-176's Avatar
Cobra Make, Engine: Contemporary classics 3041,sbc 350(have no fear ford guys for there is a FE 428 in the garage waiting to be rebuilt & installed) but for now she is a driver while other projects take precidence.
Default I think I found it!
http://cgi.ebay.com/ebaymotors/ws/eB...category=34198
If this is it, looks like a nice aluminum Fe manifold but nothing real special (no offense) just a regular 428 manifold..
I could be wrong!
Have a good one,
Dan
THOUGHT FOR THE DAY: There is more money being spent on breast implants and Viagra than on Alzheimer's research. This means that by 2030, there should be a large elderly population with perky boobs and huge erections and absolutely no recollection of what to do with them.
Old 05-28-2004, 09:21 AM
Club Cobra Member
Default I bet you found it, I missed that one.
It definitely looks like a CJ manifold but weren't CJs cast iron?
I think it's an aluminum CJ manifold which seems pretty unusual to me. I don't know a lot about 428 stuff though.
I don't think it's non-sidewinder medium riser manifold because it has four holes not 2 oval.
My vote is it's a '68 CJ/PI/SCJ cast in aluminum instead of iron. Probably a pretty decent manifold if it's like a PI.
Chuck
Old 05-28-2004, 09:30 AM
Club Cobra Member
Default Check this out.
Here is a site with intake pictures.
Intake Pictures
I'm going out on a limb and declaring it a 352 HP intake.
If it's from '68 why would it have an oil fill tube?
Chuck
Old 05-28-2004, 10:21 AM
Power Surge's Avatar
I own that same exact intake. It's a 63 low rise intake, most likely off a 406 Galaxie I was told. I bought mine from ebay as well. The guy had it listed as a 428 PI intake, so I bought it like a dumbass, instead of doing my homework. I paid like $350 for it I think. But after talking to some FE gurus, I was told it's a good intake for my FE Cobra build up, all I might need to do is port match the ports for the Edelbrock heads. It was also in perfect shape, no cracks or damage, and had the metal shield still on it underneath. I was told I paid a fair price for it and it should perform well. Also, it has the proper look for my 427 S/C clone build. The 428 CJ intake does NOT have the oil fill tube, so it wouldn't have had the look I wanted anyway. The CK8 number is just a casting code, mine says something like EF6. the rest of the intake is identical. Mine does have the casting number on the number 1 intake runner though. Maybe a previous owner of your intake ground it off to try to pass it off as a later CJ intake.
Hope this helps.
Sal
Old 05-28-2004, 10:43 AM
Ron61's Avatar
Post
Chuck,
You are correct about the 69 CJ and SCJ intakes being cast iron, but you could order the aluminum high riser which they got from Edelbrock. That is what is on my original 69 Ford Torino Cobra.
Ron 61
Ronnie Widener
View my Miscellaneous Gallery
Old 05-28-2004, 10:47 AM
So is it single plane or not?
Old 05-28-2004, 10:57 AM
Club Cobra Member
Default No it's dual plane.
No it's definitely dual plane. Not a bad intake though from what I've read, for standard or CJ heads.
Chuck
Old 05-28-2004, 11:00 AM
Club Cobra Member
Default 63 Low Rise - I'd believe that.
Sal -
I'd believe '63 low rise intake too.
Chuck
Old 05-28-2004, 02:14 PM
FFR428's Avatar
Cobra Make, Engine: HM-2027 / 427 SO
Yep a lowriser for sure. G.
Old 05-28-2004, 05:10 PM
Woodz428's Avatar
Arrow
The oil fill tube and PCV opening in the back are definite indicators of an early manifold (pre '65)
WDZ
Old 10-14-2004, 07:46 PM
I am new to the forum, is there a date code above the thermostat? Anyone needing a 406 tri-power orig. intake,
carbs, air cleaner, two sets of heads, long cast iron headers.
engine needs detuned, has 13.5 to 1 Jahns pistons, very salty
cam, and needs #2 cylinder sleeved. origional dual point
dist. motor on stand in shop for 20 years. all #s 62-63
asking 3,500.00
