February 2026
Old 06-09-2004, 01:48 AM
Cobra Make, Engine: Crendon 406FE(Southern Automotive)
Default Air filter
Hi,
I am considering using a Stellings air filter and K&N hi flo filter on a 406 with turkey pan. I would like to keep as original as possible.
Do you think this will restrict the air flow, the stellings filter seems to be very thin and small to cope with the amount of air the engine needs.
On the other hand if that,s what was on the car originally then it must be OK!!!
Any comments and advice please.
TIA,
Peter.
Old 06-09-2004, 03:37 PM
FFR428's Avatar
Cobra Make, Engine: HM-2027 / 427 SO
It's cool to see another 406 cobra. Mine has the original tripower induction so I can't comment on the Stellings air cleaner but have heard some say the air cleaner is too small to be effective. But with all the guys running these on 1x4 and 2x4 setups I find this hard to believe. What year is your 406? Mine is a 63. G.
Old 06-09-2004, 07:03 PM
SCOBRAC's Avatar
Cobra Make, Engine: -Sold- Contemporary 427S/C # CCX-3152 1966 427 Med Rise Side Oiler, 8v 3.54:1 Salisbury IRS, Koni's.. (Now I'm riding Harleys)
nope.
michael
A man that is young in years, may be old in hours, if he have lost no time. But that happeneth rarely. Generally, youth is like the first cogitations, not so wise as the second. For there is a youth in thoughts, as well as in ages... Sir Francis Bacon (1561-1626)
Old 06-09-2004, 10:02 PM
CJ428CJ's Avatar
Cobra Make, Engine: ERA #629, BBM Side Oiler Block, 482ci, Richmond 5 speed
Peter,
There have been lots of previous posts regarding stellings air cleaner with K&N filter. Some say the stellings filter makes minimal difference in HP. Others say a big difference. If you do a search you should finds lots of threads.
Chris
Old 06-09-2004, 10:35 PM
Cobra Make, Engine: Lonestar LS 427, Keith Craft 501,Toploader
Yes, those filters do seem small, and by themselves are too small. But, with the hood closed and you driving, it creates a pressurized air box which flows more air than a much larger air filter, also flowing only cooler air ( which is MUCH better).
Tim
" It ain't no big deal"
Old 06-10-2004, 01:06 PM
Cobra Make, Engine: SPF 406FE
I'm running the Stellings/K&N - turkey pan combination, and really wouldn't do it any other way.... I know mine gets plenty of what it needs !!!
Sit back down and relax .....speed is just a product of fire and gasoline....
Old 06-11-2004, 04:40 AM
Thanks for the replies. I did a search and there is plenty of material on this question. I am going to stick with the Turkey pan and Stellins/K&N combo, I want to keep as original as poss.
Peter.
Old 06-22-2004, 06:44 PM
Cobra Make, Engine: ERA 377 - 428SCJ
Default Air filter
I have the Stellings air cleaner with the foam element. I have not seen a K&N filter that fits the 8.5" (Ithink) diameter of the Stellings. Can someone tell me the correct K&N part number please.
Thanks
Terry
Terry
Encino CA
ERA 377
428SCJ
Old 06-24-2004, 06:38 PM
chopper's Avatar
Cobra Make, Engine: Previous ERA owner on break
K&N makes a small 7-inch filter for racing applications. I have a pair of them on the two Holley 6224s on my car. It's the only one I've found which will fit up inside the hood scoop cutout on the ERA hood if you have the two 4-barrel setup, but should work for your application also. Filter is K&N model number E-3402. Here's a link:
http://208.196.170.231/cgi-bin/univ.pl
I had to special order them through the local Loper's speed shop in Mesa.
If the 7-inch ones are too small, and you have the dimensions of the filter you need, you can go to the K&N site using this link:
http://knfilters.com/universal/univsearchin.htm
Enter the size and shape you need and it will tell you if they have any filter to match. Keep in mind that the K&Ns are designed for long life; you clean and re-oil them rather than replacing them. As such, they're expensive; the two little 7-inch ones I bought were about $32 apiece.
Some folks drink from the fountain of knowledge; others just gargle.
Yesterday's flower children are today's blooming idiots.
Old 06-24-2004, 11:20 PM
Cobra Make, Engine: Everett Morrision FE 427 so 2-4s
why do they make those large round and tall air cleaners then?While I have those Stelling and Helling air cleaners I do think they are restrictive.I probably will never see there limits.
Mike H
