February 2026
Old 06-26-2004, 10:30 PM
Default cam card and recamendations
I thought I was beyond all this now I'm retiming my cam and running the rockers again.I know the cam card is priseless.I put the card and timing recamendations somewhere.I didn't throw it out.I've gone through piles of instructions and receipts,not yet.I know I put it somewhere on purpose .I do not remember where that was.Do you think with the numbers on the end of the box in the age of computers Comp Cams will be able to recreate some of the paper?
Mike H
Old 06-27-2004, 08:33 PM
Comp keeps good records.
Call or e-mail them with the part# on the box.
They can fax or e-mail you a copy of the cam card.
--Mike
They bend 'em, we mend 'em.
Old 06-28-2004, 12:15 AM
Mike H What is the cam number on the box ? I have a couple of catalogs with the numbers in them. Rick Lake
Old 06-28-2004, 05:46 PM
Cobra Make, Engine: None yet, saving $ for a Kirkham. Buy a FE from me and I'll be that much closer.
Mike,
I bet you can get everything you need from their website. They have real good specs on all the cams right there on the web. Just type in your part number at the main page and it will take you right to the detailed specs. it's
www.compcams.com
....I think... but if not, just do a search... they are easy to find
Randy Ritchey
Thanks for looking and have a blessed day!
"For whosoever shall call upon the name of the LORD shall be saved."
Romans 10:13
Old 06-29-2004, 08:29 PM
Itsays accross the top of the lable that it started as 33-000-5 custom cam core ,lower accross the middle it says FB 6212 /6215 S 110.0 which I under stand is solid lifter 110 ° of seperation. across the bottom SERIAL # X 6622 200220 I called, a duplicate card will not be coming and duration is at .050"lift 241° intake ,252° exhaust lift is .588" intake,.598" exhaust 4° advance is built in so install straight up.
Mike H
