Old 08-27-2004, 09:18 AM
WBofTN's Avatar
Default 429 question
I'm looking a cobra for sale with a 429 or 428 - the owner has
mentioned both # in my conversations with him. I ask for the block #, and he crawled under the car to look. He informed me that
the starter was partially covering the #, but the part he could
read was {DOVE......}.
Can anyone inform me on this subject? before I go and look at
the car.
Thanks
WB
Old 08-27-2004, 12:42 PM
Tom Wells's Avatar
Yo WB,
D0VE (dee-zero-vee-eee) is a very common number on 385 series (429/460) blocks, and is located above/behind the starter.
Another way to identify a 385 is to look at the valve covers. There will be three bolts holding the valve covers on the intake manifold side of the head, and four bolts on the exhaust side of the head. Note that some 385 covers omit the center bolt on the intake side.
Sort of like
INTAKE side
x (x) x
x x x x
EXHAUST side
FEs are different...
Tom
Old 08-27-2004, 01:40 PM
WBofTN's Avatar
10-4 Tom
Sounds like its a 429
WB
Old 08-27-2004, 02:45 PM
Cobra Make, Engine: Lonestar LS 427, Keith Craft 501,Toploader
A 429 and a 428 are two totally different engines that are not even close. You dont need #'s to identify. A 429, 385 series, which is the same as a 460, is the largest sizewise. A 428, or FE, looks like part of its intake is a part of its head, like 390's and 427's.
Tim
" It ain't no big deal"
Old 08-27-2004, 03:03 PM
Cobra Make, Engine: 427SC Unique
On a 385 series motor the intake does not extend under the valvecover like a FE does. The 385 intake is smaller and the heads are larger than an FE. The intake and exhause ports are oval.
Brent
