Old 10-08-2004, 10:52 AM
luke-44's Avatar
Default Thermostat Orientation? - Which way?
I can't believe I am not sure which way the thermostat goes, but in my racing days I just used a punched out core - it''s been years since I had a thermostat out of a street car....Anyway.....
....does the flat side go towards the expansion tank or the engine? Or conversely, does the raised thermostat side go towards the expansion tank or the engine?
Your help as always is most appreciated.
Bruce
Enjoyment may be 9/10's anticipation, but that last 10% is oh so sweet....
Old 10-08-2004, 12:21 PM
relaxinrob's Avatar
Cobra Make, Engine: FFR Daytona Coupe done to replicate CSX-2299 at the '64 LeMans
flat side with spring goes in the intake first, domed side sticks up under the thermostat housing.
Replicas are the highest form of flattery!
http://www.rehobothproperties.com/coupe.htm
Old 10-13-2004, 01:27 PM
Check the thermostate housing. It should have markings that point towards the radiator. relaxinrob got it right!!
Good Luck
FE Specialties Your West coast FE source. We build FEs with todays technology, not circa 1970. We can supply you with any type of engine and drive train parts. From mild to wild. We engineer engines, not just throw parts at them. I currently am campaigning a 67 coupe that has C4AE-G iron heads, full interior, 3300 lbs. 10.51 @ 130.5mph. 665 HP(revised) with 11.6 to 1 comp. single 4 barrel.
Thanks Much. Tom
Old 10-21-2004, 07:31 PM
Cobra Make, Engine: B&B non-donor, 496 Genesis SO (608 HPwith 9.4:1 CR), Tremec TKO, Currier 8.8
For any thermostat for any car, the bimetallic spring goes on the engine side. The engine side is where the coolant gets heated. When the coolant gets warm enough, the spring opens the valve and lets the hot water out to the radiator.
Good luck.
Brian
Old 10-21-2004, 07:59 PM
vettestr's Avatar
Cobra Make, Engine: Cobray-C3, The 60's body lines on todays chassis technology
Hey Luke,
For giggles and grins prove it to your self and verify opening and closing point. Throw in a pot on stove with a t-meter. Watch it open and note degrees. Add a little cold water to pot and note closing temp.
Now you know set points and can see flow direction. Everybody gave great info and said water leaves block towards rad. It should open towards flow direction.. its that easy
Jeff Classic
Manufacturer of the Cobray-C3
www.cobrasnvettes.com
