Old 10-24-2004, 01:52 PM
Cobra Make, Engine: None yet, saving $ for a Kirkham. Buy a FE from me and I'll be that much closer.
Default NASCAR 427 rod bearings?
Maybe somebody can shed some light..... I've never seen one of these cranks or any rods in person, but I know they have wider rod journals to accomodate wider rods (.080"). My question is, where can you buy the bearings. And better yet, in a FE, the rod bearing doesn't even come close to covering the full width of the rod, so why would it hurt to run a normal FE bearing if it is a measly .080" narrower? Bearing technology has come a LONG way since they built these, and unless the locks are located differently, I can't see why it wouldn't work. You might have to open up the oil hole in the bearings a little bit, but how hard would that be? Comments please....
Randy Ritchey
Thanks for looking and have a blessed day!
"For whosoever shall call upon the name of the LORD shall be saved."
Romans 10:13
Old 10-24-2004, 04:03 PM
ted ted is offline
You'll find that rod bearings do not cover the full face of most connecting rods due to having to insure clearance for the radius in the crankshaft journal. The high performance bearings can be even narrower than the standard passenger car pieces due to high performance crankshafts typically having a larger radius at their journal edges. Most high performance connecting rod bearings will be individually marked "upper" and "lower" in order to maximize bearing contact surface while maintaining adequate clearance for the journal's radius. If you'll examine the rods, you'll also notice that the rod will have a larger chamfer on the journal's radius side for the same reason.
As loading on the bearing increases, then the surface area for the bearing where it resides on the journal will also be appropriately increased either by journal diameter or bearing width to keep wear within reasonable levels.
Ted Eaton.
Fe's are fast but "Y-Blocks" are fun when they run in the 9.60's at 135 mph.
Old 10-25-2004, 05:13 PM
Cobra Make, Engine: FFR #4928,427SO MED RISE,2-4,FULL ROLLER,TREMEC 5-SPD,TRU-TRAC 3.73
hi,i have a nice nascar crank and rods and was just as puzzeled about the bearings.after i talked with lee holman of holman & moody,he assured me that they used standard width bearings with no problems.nascar parts are for sale.thanks
Old 10-25-2004, 10:28 PM
The Bearings we've used on our 1.840" wide Journal Cranks you can buy from Federal Mogul as 8-7170CH. Watch the journal widths as sometimes the cranks have been ground out to 1.850" and this may well require a different rod with better side clearances like these Crowers.
George
http://www.gessford.com/work/images/DSCN2252.JPG
http://www.gessford.com/work/images/DSCN2256.JPG
http://www.gessford.com/work/images/DSCN2257.JPG
Old 10-26-2004, 12:50 AM
BMK's Avatar
BMK BMK is offline
George,
Hope you can sell some bits here, you look busy, good to see..
Bernie Knight
Old 10-26-2004, 11:52 AM
Default Thanks George....
It's always nice to hear advice from the pros....
Does the heat from that grinder hurt the rods at all? I've always been advised to avoid narrowing (or balancing) rods by way of a grinder type machine, but rather use a mill to cut them down.
Randy Ritchey
Romans 10:13
Old 10-26-2004, 10:15 PM
In the case of the Crower rods in the images we buy them wide and then side clearance to the journals...the rods checked, balanced, rechecked...and of course we keep the heat to a minimum on any metal removal.....the magnetic base grinder works well for side clearance work.
George
Old 10-27-2004, 09:42 AM
BMK's Avatar
BMK BMK is offline
Thumbs up Hey George - "Good day mate"
rritchey
Not only a Pro but he is considered a legend "Down Under"..
Up there with the "Crocodile Man" - Steve..
(Sorry George....)
Bernie
Bernie Knight
Old 10-28-2004, 12:50 AM
C-J C-J is offline
Default Crower rods
George,
How much are these semi finished rods from Crower?
I would need a set for a NASCAR crank I have....
Thanks!
C-J Englund
