February 2026
Old 10-29-2004, 04:14 AM
chuckbrandt's Avatar
Club Cobra Member
Cobra Make, Engine: ERA # 665, 390 (to start with) Toploader
Default Lakewood clutch fork boot?
Do you folks running a lakewood bellhousing on an FE have a rubber boot around the clutch fork? If so where do you get one or what application stock boot works?
Thanks, Chuck Brandt
Build website at www.chuckbrandt.com
Old 10-29-2004, 11:25 AM
wicked fast's Avatar
The longest build.....
Cobra Make, Engine: Mid-States, 428 Police Interceptor, TKO 5 speed, Jaguar rearend, Trigos, and Guardsman Blue!!!
TTT
I need one too !!!
Best,
BC
If you were to die tonight, are you 100% sure
that you would go to Heaven ??
www.bluecarministries.com
Old 10-29-2004, 11:48 AM
Big-Foot's Avatar
Cobra Make, Engine: RCR GT40 #45
We've never run them in any of the cars we have built. In my opinion, they are not needed unless you are off-roading your vehicle and there is a potential to get debris in the bellhousing.
Running without the boot will also aid in clutch cooling which you need far more than debris protection.
My $.02 worth anyways..
Regards - Randy
RCR40 #45 http://www.GT-Forty.com
Old 10-29-2004, 12:15 PM
Club Cobra Member
Default I'll keep you posted
Bill -
I ordered a stock big block mustang one from NPD this morning, I'll let you know if it fits. It looks like it _might_ ...
Randy -
That's a good point, and since there are 3 large holes in the front of the motor plate it really doesn't seal much.
My concern was grit working into the throw out bearing...
CDB
Old 10-31-2004, 07:19 PM
Cobra Make, Engine: ERA 427 w/496 Side Oiler, roller, dual quads
C6OZ-7513-A (69 Mustang and others) works, doesn't completely cover the hole, leaving an open area about 1" or so towards the front or rear.
Old 11-08-2004, 08:04 AM
Club Cobra Member
Default Yep that's the one I got.
That's the one I got C60Z-7513-A. Not even close to looking like it will fit. I'm going to try to call lakewood for some support.
Chuck
Old 11-08-2004, 12:44 PM
Club Cobra Member
Default Lakewood's Reply
Here is their response, kinda lame, I guess I don't really need one. CDB
Question: Brand: Lakewood
I have a lakewood bellhousing for the FE. Is there a clutch fork boot available that will fit? A stock one doesn't. Thank you, Chuck
Vehicle/Engine Specs:
Make: Ford Model: Cobra Roadster Replica Year: 1965
Engine Type: 390 Transmission: Toploader
Modifications: None that are important to the question.
Discussion Topics: bellhousings
Solution:
Sorry no there is not one available. Most people use a shifter boot trime it to fit. Thanks
Attachments/Links:
Old 11-21-2004, 05:23 AM
Chuckbrandt Chuck you need to weld a spacer plate to the opening for the boot to work. 1" to 11/2" width flat steel. works Bent it a little for the curve. Down side is there is no air space to let hot out and cooler in. It will keep the weather out but how many times are you going to drive in the rain or snow?Make sure the lever has full range of travel. Rick Lake
Old 11-23-2004, 02:44 PM
need4speed's Avatar
Cobra Make, Engine: Beck Lister-Corvette
Lakewood gave me a similar response although it was not for exactly the same application. I just took some sheet rubber that they sell at Harbor Freight for tool box liners, cut a piece to fit, and used weatherstrip adhesive to attach it. So far it has worked just fine.
Racing in a straight line is motorized bowling.
Taking corners (on a track) is a real sport.
