Old 01-28-2005, 10:06 PM
Cobra Make, Engine: KMP329 w/KC489 Shelby
Default Finally got engine in the car. What's next? Replace the clutch!!!
Doh. Others may have know this, but I didn't. I wanted to use a 12in diaphram pressure on my Shelby engine with a TKO600. Naturally, I assumed it would be the FE (427) pressure plate as did the supplier. What I didn't know was McCleod makes two 12in pressure plates for the FEs, one for big output (427)and one for small output shaft (390) toploaders. If you are using a slave and normal TO bearing and the Tremec transmission, you need the small output version. The face of any TO bearing will be too small for the fingers of 427 pressure plate. I would tell you not to ask me how I know this, but you have probably already figured it out.
p.s. I don't know if this is a problem for those using the hydraulic TO bearing.
Old 02-05-2005, 11:02 PM
SCOBRAC's Avatar
Cobra Make, Engine: -Sold- Contemporary 427S/C # CCX-3152 1966 427 Med Rise Side Oiler, 8v 3.54:1 Salisbury IRS, Koni's.. (Now I'm riding Harleys)
Actually 427's used both, early and later early units were smaller later units were larger... You only make this mistake once.
michael
A man that is young in years, may be old in hours, if he have lost no time. But that happeneth rarely. Generally, youth is like the first cogitations, not so wise as the second. For there is a youth in thoughts, as well as in ages... Sir Francis Bacon (1561-1626)
