Old 05-28-2005, 05:06 PM
elgecko's Avatar
Cobra Make, Engine: Scratch build......a little every day.
Default harmonic balancer and pointer problem???
Just a simple question. Does my image show the approximate location of my balancer with the pointer??? Not the timing marks but the balancer being too far in or out. It just seems my old STOCK pulleys don't line up. The crank spacer is installed and crank bolt torqued down. I have an Edelbrock water pump.
I'm planning on using March FE pulleys #1910. Will spacers be necessary ???
55 mph is unsafe at any speed. Huh?
Old 05-28-2005, 06:18 PM
trularin's Avatar
Member of the north
Cobra Make, Engine: A Cobra
I had to make a spacer on my lathe for one of the belt drive attachments. You may want to check a few things before you continue.
I mean by the look of it, the balancer is not on the crank all the way.
If it is, there is a good distance from the cover seal and the back of the balancer.
Just a thought.
Old 05-28-2005, 06:46 PM
Cobra Make, Engine: CSX4000, 427
That looks about right.
"After jumping into an early lead, Miles pitted for no reason. He let the entire field go by before re-entering the race. The crowd was jumping up and down as he stunned the Chevrolet drivers by easily passing the entire field to finish second behind MacDonald's other team Cobra. The Corvette people were completely demoralized."
Old 06-13-2005, 05:53 PM
Cobra Make, Engine: not yet, gathering parts for ffr
Worked at ford in the day they built those. a lot of engines were built with whatever parts they could make fit due to supplier problems. you can't always go by the book for replacements
