November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 06-19-2005, 07:10 PM
Default Did all FE blocks have cast numbers?
I bought an FE sight unseen in Michigan....Trularin was kind enough to pick it up for me. It was in a '78 Ford F700 (not original engine -- had been transplanted) dump truck. It's got a 361 tag on the valve cover....the valve covers straddle the intake and head, so I know it's an FE...but Tru can't find a cast number anywhere on the block. He did say it had the vertical ribs on the block....so I guess it was a service block.
The valve covers have D7 (I think) cast numbers....so I take it this is a 77-78 engine.
Tru did find a mold number on the block....but he can't find the block cast number itself on the opposite side.
Did all blocks have cast numbers, or were some cast without them?
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
Old 06-19-2005, 10:34 PM
Ford428CJ's Avatar
Not all FE's have casting #"s! The over the counter sevice blocks from Ford didnt have casting marks but they do have the ribs on either side of the block. "JMO"
Wes Adams FORD428CJ
Built Ford Tuff With Good Ford Stuff
03 F-250 Crew Cab 4x4 6.0 and 35's
64 Falcon X-Ram 428
55 FORD Truck 4-link Rides on air with X-Ram 428
2000 Yamaha V-MAX VMOA#4277
2000 Yamaha 700 Mountain Max
2001 Polaris 600 Edge X
2001 Polaris 500 SP
Old 06-20-2005, 05:36 AM
trularin's Avatar
Member of the north
Cobra Make, Engine: A Cobra
Your's doesn't.
But there is a nice mouse nest behind the starter.
Old 06-20-2005, 05:41 AM
Ah, let him stay. He'll move when the thing fires up.
Old 06-20-2005, 08:03 AM
MetaJacko's Avatar
Cobra Make, Engine: Metaline 1969 Ford 390 bored to 402ci
I don't have casting nos on mine, or ribs ether
Oh well, Its running nice anyway
Old 06-20-2005, 02:54 PM
FFR428's Avatar
Cobra Make, Engine: HM-2027 / 427 SO
It does sound like a 70's service block. You can tell by the date code. The 70's blocks had two dots under the first number in the date code. There was also a run of blocks with no casting numbers from 68 I think but they had no ribs on the side. G.
Old 06-20-2005, 03:29 PM
FFR428's Avatar
Hey Wes, nice to see you on the forum here!
G.
Old 06-20-2005, 08:07 PM
ENTDOC's Avatar
I have a 427SO hydraulic block with no casting numbers or ribs. chuck
Old 06-20-2005, 11:27 PM
Ford428CJ's Avatar
FFR 428,
I thought that I would check out some of the othere Forums to see the Hap's!
Wes Adams FORD428CJ
64 Falcon X-Ram 428
2001 Polaris 500 SP
Old 06-21-2005, 02:14 AM
MetaJacko's Avatar
Hi,
Just re-read the Email you sent me a couple of months back.
Mine turned out to be late 69 which fits into the above.
Any idea why they didn't put the normal casting nos on?
Paul
Old 06-21-2005, 06:06 PM
Cobra Make, Engine: 428 cj
My block has no casting number or ribs. It does have a date code 8k23. Also 66-427 on back with a big C cast into it. Also an X in the lifter valley with 47 under it. The front has 68 352 on it. Don't know if it has 428 cast in the freeze plug hole.
What does the big C on back and the X in the valley mean? Anyone know?
Old 06-21-2005, 06:46 PM
X in the valley means high nickel content...
Old 06-22-2005, 04:59 PM
FFR428's Avatar
The "X" debate is still out to lunch. I'd lean more to a HD block casting that high nickle content of the "X" mark in the lifter galley. The "C" in most cases represents an CJ/SCJ block application.
Old 06-29-2005, 02:46 PM
SCOBRAC's Avatar
Cobra Make, Engine: -Sold- Contemporary 427S/C # CCX-3152 1966 427 Med Rise Side Oiler, 8v 3.54:1 Salisbury IRS, Koni's.. (Now I'm riding Harleys)
No... In the interest of stirring up @#$% I would say the best FE blocks have no casting numbers.
X blocks have the thickest cylinder walls... Just weigh one, or my case pick one up... C blocks have reinforced crank saddles. Some X blocks have both...
michael
A man that is young in years, may be old in hours, if he have lost no time. But that happeneth rarely. Generally, youth is like the first cogitations, not so wise as the second. For there is a youth in thoughts, as well as in ages... Sir Francis Bacon (1561-1626)
Old 06-29-2005, 05:56 PM
Ibr8k4vetts's Avatar
Are you sure it's a FE.... It could be a FT
Mike Z
Old 06-29-2005, 06:25 PM
Yeah, it's an FT.
Complete running 361FT with Clark tranny.....
Old 06-29-2005, 07:29 PM
Cobra Make, Engine: shellvalley 428 ford
brent, no not all fe's had casting #'s. especially service/parts replacement blocks.
byron
