February 2026
Old 07-19-2005, 06:11 AM
Cobra Make, Engine: LA Exotics, 351C/T-5 trans. Guardsman Blue
Default Hydraulic Clutch Kit for an LAE
My clutch cable broke on the way home from work Tuesday and now my car is down again. BUMMER!! I have a cable operated clutch and was told to switch it over to a hydraulic clutch setup. Do any of you fine folks know where I could buy an entire kit to do that?? My cobra is an older LA Exotics with a 351C. THANKS!!
Old 07-19-2005, 06:35 AM
Cobra Make, Engine: unique 427 302/300hp t/5
Default clutch hydrulic kits
for starter you can try autoworksracing. hope this helps
Old 07-19-2005, 07:01 AM
Seasoned Member
Cobra Make, Engine: Unique 427 S/C, Dart 427W "Replica" Ford engine
National Parts Warehouse has a conversion kit listed on their web site for Mustangs that should work, with a little tweaking.
Bill Stradtner
Old 07-19-2005, 11:11 AM
Clois Harlan's Avatar
All you need to do is go to Summit Racing or Jegs and order a complete McLeod or Howe Hydraulic T/O Bearing kit for your particular engine and transmission (about $350). In the kit you will receive a master cylinder,reservior, spacer, throw out bearing with fittings and hoses. It can be easily installed in a few hours. Your LA Exotics already has the holes marked for this application. If you have any questions call Barry McGill at B&B (the successor to LAE) and he can answer most or all of your questions.
The replacement cable will cost you around $75 just for comparison.
Clois
PS- I just noticed you are in San Diago. Drive up to McLeod or PAW and pick the parts up and save the freight. If you have specific questions call Red after 10:00 am at McLeod (they are on the internet as is P.A.W.)
"Let's roll"
"Be part of Something Good
Old 07-22-2005, 06:44 AM
Clois: I have a Lakewood bellhousing. Will that cause me problems with one of the hydraulic clutch kits or a hydraulic throw out bearing kit?? THANKS!!!
