January 2026
| S |
1 |
| 4 |
5 |
8 |
| 11 |
12 |
15 |
| 18 |
19 |
22 |
| 25 |
26 |
29 |
30 |
31 |
04-04-2006, 07:53 AM
OH
Cobra Make, Engine: CSX4000, Shelby aluminum 496 ci FE
427 stroked with 428 crank balance question
I have a Dove aluminum 427 tunnel port that was stroked with a 428 crank and rods. It has an aluminum flywheel that I want to replace with a light weight steel unit since I'm putting it in a heavier car (mustang). My question has to do with the balance. Can I reasonably assume that it was internally balanced and therefore would use a zero balance flywheel? I didn't build the engine initially and I know there are balance differences between the 427 and 428CJ engines. The aluminum flywheel that came on the engine doesn't have counterweights cast into it but it has been drilled a number of times. (probably for different balance engines?) I don't want to have to take this thing to a shop just to find out how it's balanced just so I can buy a new flywheel for it. As far as i can determine, it was originally built by a shop called S&S engines possibly in Iowa. Any input greatly appreciated.
Doug
CSX4761
ERA #115 - sold
ERA #002 - sold
07 GT500
66 GT350 tribute
70 Mach 1
65 Comet gasser
Advertising
04-04-2006, 09:01 AM
I don't think you have any choice but to take the old & new ones in to have the balance matched.
I'm running a neutral flywheel on a 428. There's no balance weight cast in, but the machinist drilled the opposite sides to acheive a 428 balance.
If you have holes drilled in your current flywheel, you're definitely not neutral balanced.
04-04-2006, 09:30 AM
IL
Cobra Make, Engine: ERA 454 S.O.
Don't be so sure of that statement. Depending on how many, and how big the holes are, this could be to done to get a zero ballance.
I use to work for GM in the flywheel dept. almost every wheel had hole drilled in them.
Jeff
“If you can make black marks on a straight from the time you turn out of a corner until the braking point of the next turn, then you have enough horsepower.”
Mark Donahue
04-04-2006, 10:55 AM
OH
That's what I figured....or it had been drilled to balance for a variety of engines. There are numerous holes drilled in it. I guess to find out for sure I could take the existing flywheel in to check the balance on it.
Doug
CSX4761
ERA #115 - sold
ERA #002 - sold
07 GT500
66 GT350 tribute
70 Mach 1
65 Comet gasser
04-04-2006, 11:01 AM
OK
If your 428 flywheel came from McLeod there was a small rectangular weight (28 oz) that bolted to the top of the flywheel on the clutch side. This weight can be removed to achieve zero balance. Also, your harmonic balancer will have a 28 oz weight inside for balance. I know several people that are running an aluminium flywheel in their Mustang.
Clois
"Let's roll"
"Be part of Something Good
04-04-2006, 11:03 AM
CT
I bought a steel flywheel for an externally balanced 428 and it has several holes drilled in one end, but no counterweights. I had a question on indexing the flywheel (down the page) that seems to be answered.
04-04-2006, 11:07 AM
Cobra Make, Engine: ERA 427 w/496 Side Oiler, roller, dual quads
It's final balance (what it's balanced at now) is obviously for the engine it was run on. Take the old and new flywheels into your machine shop and have them balance the new one to match the old one.
Dan
Do you know why they call it "PMS"? Because "Mad Cow Disease" was taken. --Unknown, presumed deceased
04-04-2006, 01:02 PM
IL
Clois
Not to be picky, but it is not a 28 oz. weight. What 28 oz. refers to is 28 inch ounces. At a 1 inch radius, the weight would truly weigh 28 ozs. Seeing that this weight is bolted on the end of the flywheel (about a 6" radius), the weight actually weighs 28/6 = 4.67 ozs. If you don't believe me, pick up the weight, it is nowhere near 1.5 lbs.
It is entirely possible to remove weight from the opposite side of the wheel to simulate the extra weight needed on the counter balance side (inline with the crank lugs). 4.67 ozs. = 1 cu. in. of steel or 2.85 cu. in. of aluminum. To achieve this with drilling, there would have to be about 10 .5 in. holes x .5 in. deep in steel or 28 holes of the same dims. in aluminum. These calculations are close, they do not take into account the tip of the drill point if they are not through holes.
If you need help with the calcs. reply with your number, dia., and depth of the holes and I can help you.
Jeff
Mark Donahue
04-04-2006, 05:01 PM
OH
After talking with several people here locally today, I'm wondering if just trying to match the balance between the old and new flywheels will even work. They are of the opinion that the whole rotating assembly needs to be balanced as a unit. If the new wheel is drilled like the old, just being off a small amount will affect balance and cause a vibration. I'm starting to think maybe I should just keep the old alum flywheel on this application, it might be more trouble than it's worth.
Doug
CSX4761
ERA #115 - sold
ERA #002 - sold
07 GT500
66 GT350 tribute
70 Mach 1
65 Comet gasser
04-04-2006, 08:46 PM
IL
I was going to say that right from the start, but I didn't think you would like that answer.
Jeff
Mark Donahue
04-09-2006, 07:19 AM
TX
A competent balance shop can match balance the replacement flywheel to match your old flywheel. The only nuance is if the flange on the back of the crankshaft is not exactly true with the mains, then a given amount of unbalance will occur as a result of the runout at that point.
Ted Eaton .
04-11-2006, 01:23 AM
IL
Ted Eaton .
Jeff
Mark Donahue
04-11-2006, 04:31 AM
TX
Not sure what your questioning unless you don't understand how the flywheel hub at the crankshaft flange can become uncentered when the crankshaft is turned undersize. This in turn creates runout on the flywheel when installed on the crankshaft which may have been perfectly balanced on an arbor.
Ted Eaton.
Fe's are fast but "Y-Blocks" are fun when they run in the 9.60's at 135 mph.
04-11-2006, 07:27 AM
IL
Why would the flange become uncentered when the crank is ground under size? It is ground between centers. If that happens (never heard of it), you must be dealing with a totally incompetent machine shop.
Jeff
Mark Donahue
04-11-2006, 09:39 AM
It happens at competent shops; the reason you've probably never heard of it is because the amount of runout, and therefore the effect on balance, is usually extremely small.
Dan
